Extensive Supra Build - First of its kind in the world |
Aug 24, 2011 - 10:12 AM |
Enthusiast Joined Jan 28, '09 From Austin, TX Currently Offline Reputation: 0 (0%) |
Not an MR2, but I figured you guys would enjoy drooling over this just as much as we are
We have been working on a fairly extensive compound turbo setup on a customer's Supra for the last couple months. We've kept it under wraps for a while and will be slowly releasing information on the build. There are a few things being done on this car that make it the first of it's kind in the world. Keep your eyes peeled. So far: * 3.3L VVTi 2JZ-GTE built engine & head * Hypertune large port intake manifold * Direct port methanol injection in second fuel rail * Methanol injected pre-turbo and post intercooler * Custom setup Motec ECU and logging/monitoring tools * HRE Wheels * Custom Penske coilovers * Custom EMSPowered compound turbo kit * Comp Billet Ball Bearing 6465 small turbo * Comp Billet Ball Bearing 8283 large turbo * EMSPowered custom made twin-scroll equal length manifold leading to the small turbo with high precision CNC machined head flange * EMSPowered custom made up-pipe leading from the small turbo to the large one (we've nicknamed this guy the octopus, you'll see why when we post photos of it) * Quickspool valve on the large turbo * EMSPowered custom made 4" v-band downpipe * EMSPowered custom 4" midpipe with 4" boost actuated dump * EMSPowered custom 4" to dual 2.5" y-pipe to join to factory muffler for street driving * EMSPowered custom 4" b-pipe and muffler for race days * Ceramic coated downpipe and full exhaust * Ceramic coated both exhaust manifolds * Ceramic coated turbine housings * Custom built inconel heatshields for manifolds and turbine housings * Two 60mm TIAL v-band wastegates * One 44mm TIAL MVR v-band wastetgate * EMSPowered custom made 5" intake pipe & filter with v-band at the turbo connection * EMSPowered custom made intercooler with hand formed end-tanks and Wiggins clamps everywhere * EMSPowered custom made upper and lower radiator hard pipes with Wiggins clamps * EMSPowered custom made oil catch can * EMSPowered custom made coolant overflow * EMSPowered custom made power steering reservoir * EMSPowered custom made coolant swirlpot * EMSPowered custom made fuel filter mount and skid plate * EMSPowered custom made methanol pump mount and skid plate * EMSPowered custom made methanol fuel cell in trunk area behind rear seat * EMSPowered custom made battery tray and fuse box tray in trunk area * EMSPowered custom made mounts for Penske coilover reservoirs * EMSPowered custom 4 point roll cage built to exceed NASA specs * Custom hidden/stealth parachute mount built into trunk floor * Oil cooler custom mounted with custom built EMSPowered duct/shroud * Wrinkle black powdercoated water neck and radiator pipes * Wrinkle black powdercoated charge pipes * Wrinkle black powdercoated intercooler endtanks * Wrinkle black powdercoated radiator endtanks * Recaro leather racing seats * Custom racing harness There is lots more being done to this car that I'm . This is just a short list of some of the more important performance modifications. Some photos: -------------------- |
Aug 24, 2011 - 11:40 AM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
Damn, impressive. Can't wait for some numbers/vids.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Aug 24, 2011 - 12:06 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
please give me that engine! hahahah
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Aug 24, 2011 - 12:47 PM |
There's a third wastegate not shown in the photos in the first post. Here are some more photos that may help show how the manifold/turbo/wastegate setup work:
Also, here are some various photos taken along the build process: -------------------- |
Aug 24, 2011 - 1:54 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
This thing should be a quarter mile monster...But i bet a t6 would still eat it up on the freeway .. Still nice to see some new things happening with the 2j. What is the story internally? Also what tranny are you guys gonna use? v160?
This post has been edited by SupraKid: Aug 24, 2011 - 1:56 PM |
Aug 24, 2011 - 2:04 PM |
Stock 6speed transmission and differential. This car is being built to be an all around top notch performer, drag racing, road coarse, standing mile, and of course highway runs. The owner will be attempting to set a few world records with once's it's finished
Aug 24, 2011 - 5:12 PM |
excellent fabrication work bak. looks amazing.
13.6@108MPH, 5SFTE Powered |
Aug 24, 2011 - 5:16 PM |
Too much awesome for one thread.
Aug 24, 2011 - 6:06 PM |
Thanks guys.
Aug 24, 2011 - 10:16 PM |
Enthusiast Joined Mar 28, '04 From Ann Arbor MI Currently Offline Reputation: 9 (100%) |
That exhaust manifold is ****ing maze for me to try and follow from those photos.
I take it compound and sequential are the same in this case for the turbo set up? edit Got any photos with out the turbos hooked up to it? This post has been edited by neKronos: Aug 24, 2011 - 10:24 PM |
Aug 24, 2011 - 10:49 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
I fapped....
Aug 25, 2011 - 12:53 AM |
Enthusiast Joined Nov 8, '08 From Penn Valley,Ca Currently Offline Reputation: 1 (100%) |
Is all the welding done in house? Such beautiful work! I hope to see some videos of it.
Aug 25, 2011 - 9:11 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Wanna make me a manifold? LOL. Jesus. That's one nasty monster... and it's white. Do want.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Aug 30, 2011 - 1:15 AM |
That exhaust manifold is ****ing maze for me to try and follow from those photos. I take it compound and sequential are the same in this case for the turbo set up? edit Got any photos with out the turbos hooked up to it? Sequential and compound turbo setups are totally different. Let me know if you need a brief description and I'll do my best to explain the difference. I'll look and see if we have any good photos of the finished manifolds without turbos attached for you. Is all the welding done in house? Such beautiful work! I hope to see some videos of it. Yes, we do ALL of our fabrication in-house. This includes custom one-off work like this, and also our turbo kits, manifolds and other products for the MR2/Celica/Alltrac/GT4 Wanna make me a manifold? LOL. Jesus. That's one nasty monster... and it's white. Do want. Sure thing, we build all sorts of kits. Let us know what you need and we can quote you a price. Check out our website and you may find that we already make what you're looking for. If not, let us know and we can make just about anything you can dream of. -------------------- |
Aug 30, 2011 - 1:40 AM |
Really?! Oh boy! Now I'm getting excited. I'll hit you up when I can and I'll def be interested in a quote. I'm looking to build a NA daily that performs well and can be autocrossed. Already almost complete on the suspension, I just need to finish the exhaust for the next step and eBay headers are trash. They do nothing for performance boost and are made from cheap metal.
I'm glad I stumbled across this thread -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Aug 30, 2011 - 1:53 AM |
Really?! Oh boy! Now I'm getting excited. I'll hit you up when I can and I'll def be interested in a quote. I'm looking to build a NA daily that performs well and can be autocrossed. Already almost complete on the suspension, I just need to finish the exhaust for the next step and eBay headers are trash. They do nothing for performance boost and are made from cheap metal. I'm glad I stumbled across this thread We can build it from mild to wild. Drop me a line when you're ready and we can start getting a build plan together for you. -------------------- |
Aug 30, 2011 - 2:36 PM |
Enthusiast Joined Nov 18, '08 From Idaho Currently Offline Reputation: 1 (100%) |
my god!
more. -------------------- A work in (extremely slow) progress
Sep 7, 2011 - 11:43 PM |
Sequential and compound turbo setups are totally different. Let me know if you need a brief description and I'll do my best to explain the difference. I'll look and see if we have any good photos of the finished manifolds without turbos attached for you. I feel I have somewhat of a rough idea of what your system is doing. Not being able to follow the flow perhaps is throwing me off. But when I try to follow it almost seems as if its both probably because of all the wastegates you have on it. Orange is first inlet charge, brown takes charge into 2nd turbo, compressing it more and then purple takes the exponentially charged air through the IC past the throttle body into the engine. Red Exhaust goes from block to first turbo, light blue it goes from first turbo to 2nd spooling it up, green wastegates dump to 2nd turbo for full powah. Red Exhaust goes from block to first turbo, light blue it goes from first turbo to 2nd spooling it up, green it finally hits the downpipe. Sequential Series/Compound/Staged This post has been edited by neKronos: Sep 8, 2011 - 1:29 AM |
Sep 8, 2011 - 10:40 AM |
You've got that mostly correct. So the benefit of Compound versus Sequential:
Here's a good graph to explain another important part of the differences (twostage is referring to compound setups): This post has been edited by baktasht: Sep 8, 2011 - 10:41 AM -------------------- |
Sep 8, 2011 - 11:32 AM |
Nekronos, I think you're flow was backwards
should look like this Turbo 1 is attached to exhaust manifold. Turbo 2 is attached to via exhaust of turbo 1 + wastegates 1,2 Air enters via turbo 2, is compressed and sent to turbo 1. Air leaves, turbo 1 and goes through IC to TB. Exhaust exits via turbo 2 Blue = intake air red = compressed pink = twice compressed yellow = from manifold green = exhaust from T1 to T2 |
Lo-Fi Version | Time is now: November 25th, 2024 - 5:41 PM |
