High Beams have magically not worked, Total newb in auto electical. |
Aug 27, 2011 - 4:03 PM |
Enthusiast Joined Mar 28, '10 From Milwaukee, WI Currently Offline Reputation: 3 (100%) |
Here is the problem:
My high beams are currently not working, which i thought were the bulbs and replaced them, but then i notice when i turn on my high beams there is no indicator that comes on in the instrument displays. Is there a fuse for the high beams? Or is it my wiring of the headlights. i read somewhere the it might be losing its ground? Im extremely novice dealing with the electricals of the car so any help or point me to the right direction would be great. Thanks |
Aug 27, 2011 - 8:57 PM |
try to "flash" the high beams. pull the stalk towards you. if they work the circuit is good.
it might be that stalk -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Aug 27, 2011 - 9:45 PM |
yeah nothing at all..so the stalk (lights lever) is bad?
Aug 27, 2011 - 10:13 PM |
near your steering wheel there is an 18 pin connector.
pin 8 should be red-white check that with the highbeam switch on you have continuity to ground. if not, check if you have 12v to ground on the same pin. if you have a ground, its the wiring between the switch and the headlights if you have 12v, test pin 17 (white-black) for continuity to ground. if u have ground, its the switch, if 12v, there is a break between the wiring there and ground -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Lo-Fi Version | Time is now: January 9th, 2025 - 10:44 PM |
