Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) ![]() |
lets say you put your car in neutral (N), rev it up to about 2500 rpm, and then put it in drive (D).
you know how the car jerks and shakes the whole car because of all the power jumping into gear. well my cars been doing that once every other time i switch from N to D. the engine doesnt really rev but it still reacts asif im doing so. however its not constant. heres an example of today of when it did that. started the car this morning, reversed out of driveway, put it in Drive (nothing yet, acted normal like its suppose to) went to the gas station, put it in P filled up, reversed since there was a car in front put in drive again (and it 'jumped' as if i was reving the engine) any advice of what it could be on a side note: my cars making this "dhuck" sound when i accelarate from a stop or decelerate from speed, its hard to explain in words, d-man saw it and thinks its something with the tranny, but since i drive it more, i dont think so since its not coming between shifts. it feels as if everytime the the tranny goes back, it hits something strong but small (like a bolt) and them when im slowing down, its hits it again this probably doesnt make sense but i figuered if maybe u guys can give an oppinion -------------------- For Sale:OEM tail lights - make offer
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
my car did something similar when i had the tranny to throttle cable adjusted way off. i adjusted it closer n reset the ecu. it helped.
but in your case, it sounds like a bad front or rear motor mount -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
my car did something similar when i had the tranny to throttle cable adjusted way off. i adjusted it closer n reset the ecu. it helped. but in your case, it sounds like a bad front or rear motor mount How do u adjust the cable? The mount are new from toyota. But I'll check the back one again tonight. Thanks -------------------- For Sale:OEM tail lights - make offer
i made 2 videos today to explain it better:
![]() in the second one, i put the camera(phone) on tje armrest so that its stationary and u can see how much the car really shakes. ![]() -------------------- For Sale:OEM tail lights - make offer
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) ![]() |
damn, what wrong whit the oil pressure light ?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) ![]() |
I had the same problem with my old 92 stealth. in my case, it was a bad motor mount.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) ![]() |
i was thinking the same thing too. maybe it's the motor mounts?
mount.
plus... wtf is with the oil pressure light? -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
mount. plus... wtf is with the oil pressure light? Hmm now I really have to check the motor mount myself. Thanks everyone And oil pressure light according to dman: It's a canny motor. Hence when we were changing the oil pan, we saw alot of othe stuff under there from the camry which doesn't belong in the Celica. Checks the dip stick and it's fine on oil. So nothing to wrry about Took everything out but a sensor. So on idle the light blinks but goes away when it goes over 1200rpm I think. If this doesn't sound rite please let me know -------------------- For Sale:OEM tail lights - make offer
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) ![]() |
If by stuff it doesn't need would that be a large metal box that was bolted to the botom and has little cam looking things in it?
You will want to get that light fixed because its causing an issue the light is blinking every full rotation and on top of having bad motor mounts your going to tear up you bearings. This post has been edited by hatchy_gt-s: Aug 29, 2011 - 2:43 PM |
I agree with hatchy.
an oil pressure sender is an oil pressure sender no matter what car it came from. a 5s from a camry doesnt automatically need less oil pressure when its in a celica, assuming your wiring is sound (and i did a repair on your harness in that area, so unless it got burned up again its sound). -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
hard jerk from reverse to drive or just drive, bad motor mount in my case but that was in my 5s camry before.
hard jerk from reverse to drive or just drive, bad motor mount in my case but that was in my 5s camry before. Ill check the light issue too, an if it's the motor mount, shouldn't it do that on every shift rather than just from R - D or N - D? -------------------- For Sale:OEM tail lights - make offer
an auto has significantly less motor movement between shifts
but as i said theres a remote chance it could be the cable, too. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
an auto has significantly less motor movement between shifts but as i said theres a remote chance it could be the cable, too. appreciate the help. i tried to peek at the motor mount and looks like bolts are kinda loose, but not sure it was just a small peek. how do u adjust the cable? anything hard or simple (for a noob like me?) -------------------- For Sale:OEM tail lights - make offer
easy. you loosen the nuts and make the cable sit closer or further from the throttle. test, move again. it'll get better or worse.
hard jerk from reverse to drive or just drive, bad motor mount in my case but that was in my 5s camry before. Ill check the light issue too, an if it's the motor mount, shouldn't it do that on every shift rather than just from R - D or N - D? Im not saying yours is exactly the same case, but i only felt the jerk on 1st gear or reverse. not on the other gears were smooth because the car is already running smooth. 1st gear has the strongest tug. what stephen is saying about automatics is true, auto is less significant when it comes to vibration, jerk, its much smoother. So if you do feel it on an automatic, its pretty bad. But check both since thats what weve experienced. This post has been edited by trdproven: Aug 31, 2011 - 8:25 PM -------------------- 94 Celica GT
uhh.. how can u leave the bolts that hold your engine in "kinda loose"? seriously need to recheck your work before some siht really breaks again, dude
uhh.. how can u leave the bolts that hold your engine in "kinda loose"? seriously need to recheck your work before some siht really breaks again, dude i didnt do the swap myself. i paid brenton19 to do it. and even now im not saying that they're loose, i just think. the chances are high im wrong but ill still check. -------------------- For Sale:OEM tail lights - make offer
Use lube when you jerk a tranny. Wait no, wrong subject.
Sounds like bad motor mounts or loose motor mounts. Check them all, probably need to replace them all. -------------------- |
Lo-Fi Version | Time is now: February 23rd, 2025 - 2:27 AM |
