> more power from ny 5fse?
post Aug 30, 2011 - 5:58 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I want to get more power out of my 5sfe so far I have a short ram intake a header an I get a new exhaust this Saturday
what else can I do to build more power is 170 hp possible without turbo
94 st hatch my daily driver
n
post Aug 30, 2011 - 6:17 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
definatly not without alot of $$
cams will probly be ur next bet but i hear they run up in the high hundreds
This post has been edited by PolliS_5S-FE: Aug 30, 2011 - 6:18 PM
post Aug 30, 2011 - 6:30 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok but is there any little things I can do that may help some?
I found a head package on ands autosports for 1900 but id like to see a reveal of it
n
post Aug 30, 2011 - 7:35 PM
trdproven
Joined Aug 2, '05
From Guam
5sfe is a torqueee motor but it lacks aftermarket support for parts.
What you can do that is realistic is:
Turbo it, SMAAY has a bolt on kit for the most part.
Or N/A
Cams
Wires
Plugs
Intake
headers
Downpipe
Exhaust
Flywheel
Clutch
ignition
and tune it correctly.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 30, 2011 - 8:35 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok I got a few questions about doing a n/a build will a dizzy from a older model 2.2 work in my 95
so I can run a bigger external coil will a mad 6al box work on a celica
what's a good plug wire to run I have ngks but there only a 7mm wire
will port an polish work do any good on these head
where can I get a programmer at or do I just need to get a dino tune?
n
post Aug 30, 2011 - 9:04 PM
6G96GT
Joined Jan 20, '08
From East Coast
Cams aren't that pricey really. I got a set from Colt Cams for my Celica for $435 shipped back to me. Haven't gotten them yet but they're coming. Anyway, that and you can P&P the head, shave the block, tune it. Lots of money but if you got to rebuild it or something then you can do that stuff then. Otherwise, an engine swap or turbo it like others said.
post Aug 30, 2011 - 9:16 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok I might look into them andysautosports has a head package that comes with pnp head regrind cams a pnp intake an throttle body an tuned ecu
its made by hide performance it costs 1900 but I got a buddy that runs a hot rod shop that can pnp everything
im thinking about a 3sgte but not sure what year range to look for or anything like that
plus I wanna see what the stock motor will do with alittle work
n
Lo-Fi Version Time is now: February 23rd, 2025 - 4:21 AM
