> Upgrading 8" Woofers for 8 Speaker System, maybe same for 4 & 6 speaker system?
post Aug 30, 2011 - 10:55 PM
azian_advanced
Joined Apr 18, '05
From Calgary
How To Upgrade Your Stock 8" Woofers
The woofers are JL Audio 8W1V2-4 but any 8" (or 20cm) woofer will do.
Step 1: Once you've removed the woofers from the doors, you'll need to remove the 4 screws under the foam surround and pry off the old woofer.
Step 2: Then you'll need to cut the sides of the hole on the speaker adapter (shown above) to match the diameter of the magnet going on.
Note: You'll also need to cut about the same amount of metal on the doors for the woofer magnets to fit.
Step 3: Then you'll need to cut the 3 braces on each side depending on how deep the new woofers go.
Step 4: Then you tap new holes along the rim of the new woofers to match the existing anchors, and use the existing screws to mount the woofers.
Step 5: Just splice the old connector with the new speaker wire to connect to the new sub.
For best sound quality, do not use these with the factory stereo system.
Progress Pics
Old vs New
Front View of Modded Speaker Adapter
Rear View of Modded Speaker Adapter
Woofers Mounted on Speaker Adapters
Woofers Mounted on Doors
View of Woofers with Door Panels On
Lo-Fi Version Time is now: September 20th, 2026 - 12:45 PM
