noob question about paint |
Sep 7, 2011 - 5:18 PM |
Enthusiast Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) |
I'm a noob painter, but I used rustoleum semi-gloss black paint 2coats then wet sanded with 1k grit then with 2k grit then I put 1 coat of duplicolor clear wet sanded with 1k grit and 2k grit to follow again. I used 3m rubbing compound and its still not shiny.
Any thoughts or suggestions Thanks, Matt! -------------------- |
Sep 7, 2011 - 5:47 PM |
Enthusiast Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
Wut r u painting?
-------------------- From Japan to Texas my st202 follows me.
Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Sep 7, 2011 - 6:07 PM |
more clear.
Sep 7, 2011 - 6:23 PM |
I'm a noob painter, but I used rustoleum semi-gloss black paint 2coats then wet sanded with 1k grit then with 2k grit then I put 1 coat of duplicolor clear wet sanded with 1k grit and 2k grit to follow again. I used 3m rubbing compound and its still not shiny. Any thoughts or suggestions Thanks, Matt! There's your problem. Semi gloss is not gloss. Sounds like you did the rest more or less right, except I would have gone with 3 coats of paint, wet sand with 2,000 grit, then sprayed 2 coats of clear. This post has been edited by richee3: Sep 7, 2011 - 6:25 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Lo-Fi Version | Time is now: December 2nd, 2024 - 1:39 PM |
