> sanding taillight diffuser lens to clear red for my LED light boards
post Sep 8, 2011 - 5:40 AM
match220
Joined May 13, '06
From Kaimuki, HI
Since I'm redoing my tail lights to be LED, I thought I would make the lens clear red too. Basically I decided to oven-heat and disassemble my tail light for easy access to the lens. While I had it apart I decided to take a dremel to the lens with an 80 grit polish wheel and smooth out the diffuser lens. I'm still working on it, I took some 320, 1000, and 2000 grit denominations of sandpaper and polished the spot I made smooth, then I took rubbing compound/polish and rubbed it some more to make it clear. The one spot that I did it for the purpose of the video looks great, I just have to do the rest of it. I thought I would share it with you guys. Plus I'm taking out the turn signal/back up diffuser lens completely so my turn signal LED board will shine through a clear lens too.
I mention the diffuser lens polishing at around 7 minutes into the video.
tail lights video on you tube
This post has been edited by match220: Sep 8, 2011 - 6:14 AM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Lo-Fi Version Time is now: December 2nd, 2024 - 3:41 PM
