Enthusiast ![]() ![]() Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) ![]() |
Hi guys, I have been searching everywhere on how to adjust the idling on the 3rd gen 3sgte.
I just finish my 3rd gen swap, I change the spark plugs and clean the throlle body already. My car idles at 500 on start up and normal temp and it should be at 800 @ start up and 700 at normal temp. any ideas on how to adjust the idling to 700. Please help... |
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) ![]() |
reset the ECU maybe? my car idles pretty low also...
Idle is controlled by the iac valve under the throttlebody, and ecu.
You shouldn't have to adjust it manually. I would clean and lube the iac, and check timing. Both can affect idle. -------------------- Former Team 5SFTE pro member ;)
thanks, I will try that
Enthusiast ![]() Joined Apr 2, '07 From Calgary, Alberta Currently Offline Reputation: 1 (100%) ![]() |
you can adjust the idle by changing the rotation of the throttle position sensor. (TPS)
the mechanics plugged into the diagnostic and checked the throttle and adjusted the TPS. Not sure about the exact details but at least it's doesn't stall like it used to. Probably reset the ECU too. |
Enthusiast ![]() ![]() Joined Jul 29, '11 From chino, Ca Currently Offline Reputation: 4 (100%) ![]() |
this is really stupid but i ddnt realize my idle problem till about 4-5 weeks into owning a car my hvac system got stuck on so my fans and ac were on all the time idk just a suggestion i wasn't to car savy at that time haha
I advance my timing by a hair and now my car now idles at 500 at cold start and idles at 5-600 @ normal temp.
it runs good now but there is something weird going on right now. my car runs with no check engine to start and after a few minutes of driving, the check engine light comes on. what do you guys think? |
Lo-Fi Version | Time is now: February 23rd, 2025 - 5:42 PM |
