> e-brake doesnt work as it should.., need some help
post Sep 9, 2011 - 1:44 PM
diegohiga
Joined May 4, '09
From coral springs florida US
After doing a drum to disc convertion i realized my ebrake doesnt brake the car as it used to.
The first problem was that the e-brake handle used to go up too much when i pull it. Fixed by adjusting it by the center console.
By adjusting that i thought i was gonna fix the problem but it didnt.
The car brakes with the e-brake but it still mooves when i push it hard. Whats wrong?
This post has been edited by diegohiga: Sep 9, 2011 - 1:46 PM
post Sep 9, 2011 - 2:36 PM
azian_advanced
Joined Apr 18, '05
From Calgary
start by raising the car from the rear and try turning each wheel to see if they actually lock. this way you might be able to see which side (if not both) isn't working.
i'm currently have the same issue and it turns out the driver-side cable snapped somewhere inline while the passenger side was still functioning 100%. even though it feels there's tension in the cable when i pull the e-brake handle, only one side is engaging and it isn't enough to hold the car from a slight incline.
This post has been edited by azian_advanced: Sep 9, 2011 - 2:36 PM
post Sep 11, 2011 - 2:18 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The e-brake must also be properly adjusted at the wheel in order to work properly.
With the wheel off, you should find a rubber plug in the rotor hat. Removing this will give you access to the e-brake's adjuster. It's a star-shaped wheel. Use a flathead screwdriver to adjust until the rotor will not turn, then back it off eight notches.
This assumes that you installed the rotor so that it is aligned with the access hole in the hub face. If not, you'll have to remove the rotor and reposition it correctly.
Lo-Fi Version Time is now: December 12th, 2024 - 3:37 AM
