> were did you put your SAFCII?, killin me here
post Dec 17, 2003 - 12:40 AM
5sfeTurbo
Joined Apr 14, '03
Well my girl gave me the SAFCII(early gift) anyway, I keep looking at the cigarette lighter area for the install but that takes some REAL custom work considering theres a 1/4 inch gap or so. The dash area is screaming TAKE ME!! So im just gauging the ares everyone put theres. I want to start the install but this is my only bumb.
BTW, if someone has any useful info on the wirring for a 5sfe(auto) it would be appreciated.(yes..I searched bfore posting wink.gif )
post Dec 17, 2003 - 1:06 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Dec 17, 2003 - 1:13 AM
5sfeTurbo
Joined Apr 14, '03
LOL, right before I posted this topic you were just the person I wanted to talk to.
Thanks bro. How did you get it to stick up against the vent?
This post has been edited by 5sfeTurbo: Dec 17, 2003 - 1:14 AM
post Dec 17, 2003 - 1:23 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (5sfeTurbo @ Dec 16, 2003 - 10:13 PM)
came with its own little stand thing that a broke out of the tabs off of and it slides in under the vent
post Dec 17, 2003 - 1:41 AM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
I mounted mine in the glove box. Once you get it tuned you dont need to play with it anymore. Its pretty bad here to have it showing to everyone on the street. Your just asking for your car to be broken into. Also I hear that its illegal to have where I live.. or any aftermarket computer so its hidden in the glove box so I wont get defected.
post Dec 17, 2003 - 1:47 AM
5sfeTurbo
Joined Apr 14, '03
QUOTE (97sccelica @ Dec 16, 2003 - 11:23 PM)
Can you re-itterate that for me, you said you broke the stand thingy off it came with and then you slide it in?
post Dec 17, 2003 - 1:57 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (5sfeTurbo @ Dec 16, 2003 - 10:47 PM)
lol, im tired, it came out wrong.
i'll take a pic of it tomorrow for ya
post Dec 17, 2003 - 1:58 AM
5sfeTurbo
Joined Apr 14, '03
haha thanks man
post Dec 17, 2003 - 2:02 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
<<<<<< DCw / JDMart >>>>>>>
post Dec 17, 2003 - 11:11 AM
BigEdge169
Joined Nov 18, '02
From Texas
That looks real good doggy
post Dec 17, 2003 - 2:27 PM
SpedToe169
From Dallas, Tx
Mine is right below the radio. It just barely fits, but that was enough. I'll try to take pics sometime.
post Dec 17, 2003 - 4:53 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
i used that arm/hinge thing that came with it too like 95sccelica did..
night pic
David
post Dec 17, 2003 - 5:48 PM
5sfeTurbo
Joined Apr 14, '03
When doing the wirring of the T5-c diagram...how are they looking at the connectors? What I mean is the 26p connector the closest to you then the 16p and the 22p is nearest to the firewall? or is this vice versa??
post Dec 17, 2003 - 8:38 PM
RedSunCelica
From San Diego CA
I Used Velcro(sp) and connected it under the radio. that way i can remove it when im parking in a bad neighbor hood and mount it when i want to show it off.
post Dec 17, 2003 - 10:00 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
post Dec 18, 2003 - 10:29 AM
SpedToe169
From Dallas, Tx
Go to www.evilspeed.com and click on tech. I have a writeup on the SAFC install. When it calls out a pin i.e. E7-14 you're looking at the plug from the back, where the wires go in.
post Dec 18, 2003 - 2:20 PM
5sfeTurbo
Joined Apr 14, '03
Well I did it all according to www.toyotacelicaonline.com, I got nothing but a fat "check engine". I didnt even get any power. I did all this damn work, my neck hurts and my arm is cramped. I dont know what I did wrong. Anyone who has installed on a GT please....some input would be gratefully appreciated.
If you have done it correctly can you post a AIM s/n? Thank you
This post has been edited by 5sfeTurbo: Dec 18, 2003 - 2:32 PM
post Dec 18, 2003 - 3:34 PM
SpedToe169
From Dallas, Tx
If you're getting a CEL its likely because the ECU isn't getting a sensor signal that it should be.
Go to sensor check in SAFC and see if everything is working. Make sure the throttle and pressure are there, those are the most important two. Double check that the wire going from the SAFC to the ecu for manifold pressure is hooked up correctly. Make sure all your connections are good. I really recommend that you solder everything. Make sure there are no possible shorts. Everything should be taped up well, there shouldn't be any exposed wires.
Make sure your maps are all set to zero to start with. Make sure you have the right pressure sensor selected. I believe most toyotas are either 01 01 or 03 03. I've used both and they seem to work fine. Is the throttle calibrated? It should read 0% when you're off the gas and 100% at full throttle. If it doesn't go back and recalibrate it.
Don't get discouraged man. Its a complex thing and it won't always work perfect the first time. Also, don't expect it to make any power until its tuned correctly on a dyno. Until then, its just a pretty gage.
post Dec 18, 2003 - 3:35 PM
SpedToe169
From Dallas, Tx
BTW, my AIM is spedtoe169. I also have the wiring diagrams and pinouts for the GT at home if you need them.
post Dec 18, 2003 - 4:46 PM
5sfeTurbo
Joined Apr 14, '03
QUOTE (5sfeTurbo @ Dec 18, 2003 - 12:20 PM)
First off thank you for taking your time and helping me. On the SAFC I cant even get anything to appear on the screen....Maybee if the power is not going through it wont send any signals to the ECU?? I thought I did i, Speedtoe I will I/M you later tonight...thanks again.
Lo-Fi Version Time is now: November 27th, 2024 - 4:19 PM
