> fuel injector help
post Sep 11, 2011 - 1:09 AM
matts94celica
Joined Apr 20, '11
From College Station, Tx
I put supra 315cc injectors for my turbo set up. In neutral I can rev it to whatever but when I take off in first and get ~4.6k rpms it boggs down like its loading up. It does it in every gear 1st-5th. I need help into resolving the problem.
Thanks in advances and is there any post about egr dels on 7a engines?
-Matt!
post Sep 11, 2011 - 3:58 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
if your running the factory ecu then your most likely running WAY RICH, those injectors are way to big for the stock ecu. can you give some more info on your setup?
post Sep 14, 2011 - 7:18 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
Sorry i dont know much about Supra but r u sure Supra have 315cc injectors??? Or does it use 6 injectors? It sounds weird bcoz the gt4 st205 is uses 540cc injectors!
post Sep 14, 2011 - 12:10 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
without something to tune them, you will run wayy too rich
the 7a switches to openloop about 4.5, and the afr drops from 15 or so to 11-12.5, so at that switchpoint you may go so rich you dont produce power
atleast thats what my 100% stock 7a does w/ a wideband hooked up
Lo-Fi Version Time is now: February 23rd, 2025 - 11:28 PM
