> feeler: complete drop in 2nd gen 3sgte, just drop in and go
post Sep 13, 2011 - 3:09 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
ok so i am either gunna sell the whole car and start over or just sell motor and trans , what i have is a
92 2nd jdm gen 3sgte and ecu
170 psi compression on all cylinders
complete front mount intercooler set big 25x 12 core 2.5'' piping with bar that bolts in place of stock crash bar
homemade adapter on throttle body
3 inch downpipe with exhaust to get you back as far as you need with flex after downpipe
stock gt trans with act pressure plate with f1 street disc
ditching everything in bay basically so mounts , reservoir's are included
also comes with harness done by dr tweak , everything works minus ac its on there but one of the pinouts has been pulled out
motors running an rx7 maf and fuel mixture under boost pulls a pretty decent 12.5 to 13 afr motor runs around 14psi at in 3rd gear
the injector pack is new oem last spring at time of swap and i have only put prob 800 miles on this since i got it put in , have taken it on a few couple hour trips with no issues amd seems to get around 20mpg , depends how yah drive
i am sure i am forgetting things any questions just ask
just seeing if anyone is interested and what you guys thinks this setup is worth
post Sep 13, 2011 - 3:46 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
if you decide to separate any of it... i could use the 3" section of exhaust off the dp.
Lo-Fi Version Time is now: November 27th, 2024 - 9:44 AM
