> 95 st mpg.....
post Sep 13, 2011 - 6:51 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
i recently acquired a 6th gen, 95 st. has maual trans and im noticing its mpg could definitly be better its at about 25 average right now. what could cause this and how can i fix this! any help is appreciated.
post Sep 13, 2011 - 7:26 PM
matts94celica
Joined Apr 20, '11
From College Station, Tx
You could probably benifit from a tune up.
post Sep 13, 2011 - 7:30 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
ya i was thinking that, any thing specific besides the usual fluids, filters, plugs and wires ?
post Sep 13, 2011 - 7:37 PM
check your tire pressure and consider replacing the o2 sensor. Those are really the two main factors that affect mpg on an older car.
but 25mpg is not bad. you are probably driving more city than highway.
This post has been edited by lagos: Sep 13, 2011 - 7:38 PM
post Sep 13, 2011 - 8:29 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
go with a tune up and just drive conservatively; I drive 30+ miles to and from school and I use around a gallon per day
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Sep 14, 2011 - 1:59 AM
CAcelica29
Joined Aug 26, '11
From ventura, ca
ya ill get the tuneup done and try to be more conservative with it. thx guys.
post Sep 14, 2011 - 9:22 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
tune up + watch your right foot. it affects mpg most
post Sep 14, 2011 - 9:46 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Depending on elevation too. Back home in Ft. Worth, it's about ~600 ft above sea level, I'll get about 30mpg mixed. But when I'm at school in Albuquerque (~5,300 ft above sea level) I only get about 24-25mpg.
June '12 COTM
'95 AT200
post Sep 14, 2011 - 11:55 AM
Mycurse180
Joined Dec 23, '10
From PA, USA
25 is pretty bad for a 7afe celica.
post Sep 14, 2011 - 12:16 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah. temp does affect it. i lose about 3-5 mpg when its hot. mix of air density & air conditioner usage, and also fan usage(the power to run those comes freom somewhere...) i assume
post Sep 14, 2011 - 2:03 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
im not far above sea level, but it has been hot lately hopefuly see improvement in the colder months. as for a/c its broke so im not usin it
post Sep 14, 2011 - 5:35 PM
matts94celica
Joined Apr 20, '11
A cold air intake would probably help.
post Sep 14, 2011 - 5:37 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
QUOTE (matts94celica @ Sep 14, 2011 - 6:35 PM) *
not necessarily
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Sep 14, 2011 - 5:45 PM
richee3
Joined Jun 29, '08
From Denver
More air into the motor = more fuel used.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 14, 2011 - 8:41 PM
plugs, wires, cap, rotor, and most important the 02 sensor.
I used to get 34 with my ST way back in the day, with an intake (32 w/stock airbox, I know, it sounds crazy)
post Sep 14, 2011 - 9:29 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
34 would be so nice, as soon as funds allow ill be making a CAI for it as well as the tune up should help. thx for the info guys!
post Sep 14, 2011 - 10:31 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
QUOTE (CAcelica29 @ Sep 14, 2011 - 10:29 PM) *
I would just replace the stock tubing from the filter box to the intake with a pipe, and get a drop in filter. That is if you want to get better mpg while having the car sound a little better
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
Lo-Fi Version Time is now: November 23rd, 2024 - 6:24 AM
