> water pump &timing belt
post Sep 19, 2011 - 3:17 PM
kormysh8
Joined Nov 14, '09
From Saskatoon
As the title suggests. i have 340km on my 7a. timing belt broke so i should probably replace my water pump while im in there since i have no idea when the last time it has been changed. good plan? the pump isnt leaking though. so should i go by the old sayin. if it aint broke dont fix it.?
post Sep 19, 2011 - 3:19 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
For the amount of labour you're going to be paying for (or putting into it) - you might as well save yourself some dough, and time later down the road and do both at the same time.
I think the old saying "If it ain't broke, don't fix it" - doesn't apply to Timing Belt/Water pump maintenance. tongue.gif
post Sep 19, 2011 - 3:50 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
I wouldn't mess with the water pump yet if there hasn't been any problems with it. I replaced my timing belt this past December without doing the water pump and my motor (also a 7a) has about the same amount of mileage on it. (340,000km~211,000 miles; mine has ~214,000 on it)
post Sep 19, 2011 - 5:39 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (KAOS @ Sep 19, 2011 - 1:19 PM) *
YES!!!!
QUOTE (d3ath2009 @ Sep 19, 2011 - 1:50 PM) *
NO!!!!!
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 19, 2011 - 5:55 PM
pavehawk
Joined Sep 19, '11
From Ga
that is a simple call. To go through all what needs to be done to change the timing belt and not to change the water pump while your there is just throwing money away. The water pump will fail so why not have the piece of mind to know you'll not ever have to worry about it. You'll be glad you did....
post Sep 19, 2011 - 7:08 PM
Change the oil pump seal and gasket, along with the front main seal and crank seals. I bet good money they are leaking or about to start.
post Sep 19, 2011 - 8:06 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^^ good advise
post Sep 19, 2011 - 9:40 PM
kormysh8
Joined Nov 14, '09
From Saskatoon
ok, sweet. thanks for the advice 6gc.
Lo-Fi Version Time is now: January 11th, 2025 - 12:04 PM
