> 96 Celica GT Service Reminder Indicators Not Working, Instrument Panel Lights
post Sep 19, 2011 - 5:42 PM
TFFAV
Joined Sep 19, '11
From Lancaster, PA
I have a 1996 Celica GT and I am having problems with the service reminder indicators within the instrument cluster panel. I recently had the car inspected in Pennsylvania and I was told that some of the service indicators were not working so they failed the cars inspection. Some of these indicators should illuminate when the ignition key is turned to the ACC or ON position(s). Currently, the only indicators that light up when the key is turned to the ACC or ON position are the SRS Airbag Warning light that stays lit for about six seconds, the BRAKE indicator, the low oil pressure warning light and the bing bing bing sound that my seatbelt is not fastened with no indicator light showing up in the instrument cluster. The CHECK ENGINE and the ABS lights do not light up either.
I removed the instrument cluster and found the CHECK ENGINE bulb was blown (actually broken in half) so I replaced the bulb and reinstalled the instrument cluster. Per the manual, I checked the 7.5 amp fuse labeled 'instrument panel lights' in position #22 per the diagram and found the fuse to be in good working order. I also checked the 10 amp fuse labeled 'gauges and meters' in position #32 per the diagram and found the fuse to be in good working order. No change to the status of the lights as described above. My daughter did assure me that these lights worked at some point over the past year (she was away at college).
Any help would be greatly appreciated.
Lo-Fi Version Time is now: November 26th, 2024 - 7:30 AM
