> Gt4 basic infos
post Sep 19, 2011 - 8:11 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Alright, so I'm basicaly shopping around for a Gt-Four and since we don't have parts here in America I was wondering if I could still get some parts from here. I've been wondering if the oil filter is the same from the 5th gen all trac and if the brake pads and disks were the same of the ones on an MkIV usdm supra. And what are the oil grade required for the engine (guessing 10w40?) and tranny (guessing 80w90?).
Thanks!
This post has been edited by dudeofchaos: Sep 19, 2011 - 8:13 PM
post Sep 19, 2011 - 9:08 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
no on the brakes, same filter as the the 5S-FE or 3S-GTE. its a YZZ-F1. same filter as the 2ZZ-GE in the 7th gen. your oils are fine
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 19, 2011 - 10:57 PM
Neon90424
Joined Jan 19, '11
The pads on the front brakes of the supra I believe are the same...but the calipers are diff
ST205 not St185 though I dont know If you are referring to alltrac or gt-four
This post has been edited by Neon90424: Sep 19, 2011 - 10:58 PM
post Sep 20, 2011 - 10:15 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
I was referring to an St-205 Gt-Four.
post Sep 20, 2011 - 11:27 AM
Neon90424
Joined Jan 19, '11
you can find the oil filter on ebay I actually bought a 12 pack and i also bought the pads off ebay but I had to search on the forums to get an answer use the SEARCH function it helps alot!
post Sep 20, 2011 - 2:49 PM
Artega
Joined Apr 2, '07
From Calgary, Alberta
the Engine is the same as a USDM MR2, make sure it's the 3rd gen 3SGTE and most of the parts will be interchangeable.
You can get the same oil filter, oil, seals as the MR2 engine
post Sep 20, 2011 - 6:13 PM
Neon90424
Joined Jan 19, '11
avoid gasket sets for the usdm 3sgte....buy from ebay.co.uk 3rd gen gasket sets
post Sep 20, 2011 - 6:37 PM
bsamps4
Joined May 16, '10
From Raleigh
The oil specifications are available in the factory service manual. If you're in the U.S. I would recommend 10w-30.
post Sep 20, 2011 - 6:58 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (Neon90424 @ Sep 20, 2011 - 7:13 PM) *
Why so? What do usdm gaskets have?
post Sep 21, 2011 - 9:26 AM
Neon90424
Joined Jan 19, '11
nothing in common lol!
it just says 3sgte but its all 2nd gen....got a wrong cometic gasket because it didn't say...all the head gasket stuffs came wrong aswell, thermostat came way too small timingbelt cover came for 2nd gen... etc
This post has been edited by Neon90424: Sep 21, 2011 - 9:28 AM
post Sep 21, 2011 - 6:48 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (Neon90424 @ Sep 21, 2011 - 10:26 AM) *
Oh, I thought you were talking about the mr2's gasket having a problem haha
Lo-Fi Version Time is now: December 2nd, 2024 - 2:39 AM
