> Supra brakes = St205 brakes?
post Sep 21, 2011 - 9:08 PM
TheChildOfTheSea
Joined Dec 7, '10
I heard that some of the breaking parts (discs, pads...) from the 1994 Supra fits on the St205, can anyone confirm that?
post Sep 21, 2011 - 10:16 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
The front and rear pads from the gt4 calipers are the same used on supra!!
post Sep 22, 2011 - 8:01 AM
Culpable04
Joined Apr 17, '06
From New Jersey
brake disc will not fit, they are different, just the pads and rebuild kit for the calipers, the calipers use different mounting points, but internally are the same.
post Sep 22, 2011 - 10:21 PM
BonzaiCelica
Joined Apr 24, '08
ughh I so need this answered and didnt want to start a new thread. Has anybody physically seen the the SS-III twin piston calipers. I need to know if the Twin Piston SS-III Calipers use the same mounting points at the single piston Mcpherson brakes used on ST204 and ST202 SS-II Celica's! biggrin.gif
post Sep 23, 2011 - 12:33 AM
TheChildOfTheSea
Joined Dec 7, '10
QUOTE (BonzaiCelica @ Sep 22, 2011 - 11:21 PM) *
post Sep 23, 2011 - 7:49 AM
Culpable04
Joined Apr 17, '06
From New Jersey
there are 2 types of twin piston calipers, one is desinged to mount with Super strut suspension, and the other for McPherson, just make sure you get the right one for your application.
post Sep 23, 2011 - 11:49 AM
BonzaiCelica
Joined Apr 24, '08
ya ya I'm well aware of that, the twin piston mcpherson came on SS-II beams celica's with no helical. just wanted to see how far off they were....
post Sep 23, 2011 - 1:25 PM
Culpable04
Joined Apr 17, '06
From New Jersey
mounting points should be the same, because GT4 calipers will use the same mounting points as SS III calipers and they share the same mounting point, but I'm not sure if they'll be threaded or not ( GT4s are not because the thread is on the knuckle. )
post Sep 23, 2011 - 8:56 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (Culpable04 @ Sep 23, 2011 - 2:25 PM) *
gt4 and SS-III have different part numbers for the knuckles. I pointed this out in the Superstrut Suspension thread.
This post has been edited by BonzaiCelica: Sep 23, 2011 - 8:56 PM
post Sep 24, 2011 - 9:12 AM
Culpable04
Joined Apr 17, '06
From New Jersey
but at the same time SS III owners swap Gt4 brakes with no modification, everything bolts on, so mounting points are still the same regardless of different part number for the knuckles.
post Sep 24, 2011 - 1:15 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (Culpable04 @ Sep 24, 2011 - 10:12 AM) *
what ss-III owners have you talked to?? there probably hasn't been any active SS-III onwers in the past year. I believe yellowchinaman told me that differece. All celica's carry same hub so then why would they have dif part number
SS3
Knuckle, Steering Right
43211-20281 ST202
Knuckle, Steering Left
43212-20241 ST202
GT-Four
Knuckle Steering Right
43211-20291 ST205
43212-20251 ST205
I mean I know you've done your whole research and all on it with brake conversion. I'm also aware you've been here longer than I, but I've only seen one SS-III and another SS-II onwer swap over front gt4 calipers. At the same time it would make sense for toyota to use the same mounting point, hence diff part number?? stronger gt4 bearings??
post Sep 26, 2011 - 1:16 AM
Rusty
Joined Nov 5, '07
From New Zealand
There is this guy who has put GT4 brakes onto his GT SS ST202, and from what I can read the only difference between the ST20S & ST205 SS knuckles is if it's threaded or not. Not too sure what he did in the end if he just swapped to a ST205 knuckle.
He's also a member on here iirc, cant remember his name though
post Sep 26, 2011 - 2:02 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (Rusty @ Sep 26, 2011 - 1:16 AM) *
aww thanks Rusty. You finally cleared up that answer!!
QUOTE (Culpable04 @ Sep 24, 2011 - 9:12 AM) *
hmm sorry Culp you were right
This post has been edited by BonzaiCelica: Sep 26, 2011 - 2:04 AM
Lo-Fi Version Time is now: November 23rd, 2024 - 9:23 AM
