> stuck out of town car wont run under 2000 rpm , help, 3sgte swap
post Sep 24, 2011 - 1:23 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
2nd gen 3sgte swap , 94 gt , hour from home at girlfriends , car ran fine all the way here , then died taking a corner when i shifted gears , then started up and made it to her house then died when i let out throttle , now starts but wont stay smooth unless above 2000 rpm , any ideas , stumbles and dies below 2000 rpm , no codes
post Sep 24, 2011 - 2:39 PM
Neon90424
Joined Jan 19, '11
vacuum lines messed up? did you try unplugging the AFM?
post Sep 25, 2011 - 1:17 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
havent tried unplugging it but did check with carb cleaner for leaks and checks lines with no luck
post Sep 25, 2011 - 1:32 AM
mkernz22
Joined May 10, '10
From MA
try resetting the ECU by unplugging the battery for 10-20 minutes
post Sep 25, 2011 - 12:42 PM
199celica
Joined Jul 29, '11
From chino, Ca
Sounds like a bad maf sensor to me bud
post Sep 25, 2011 - 10:27 PM
ricochet1490
Joined May 3, '11
From Ohio
idle air control valve
post Sep 25, 2011 - 11:35 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
i am leaning towards maf myself as i was able to baby it home and a fewtimesup a hill fit would buck if there was any actually load
Lo-Fi Version Time is now: November 24th, 2024 - 12:36 AM
