> Which size on spacers is recomended for 6gc?
post Sep 25, 2011 - 3:31 AM
Iceman22
Joined Dec 16, '08
From Norway
Hello.
My friends whine about that I need spacers on my car, now they convinced me and I want spacers =P
I found these on ebay that are bolt-on that is quite nice.
These are the following sizes available: 15-20-25-30-38 mm
I got a feeling that 30mm will be good, but what do you guys think ??
I can have up to 38mm because the car is not low enough so it will come in the way, but 38 I think will be to much ?
2nd question, will it be best to have spacers on all tires, or will it be okay to have them in front only?
Here is some pictures how it is stock:
rear:
front:
This post has been edited by Iceman22: Sep 25, 2011 - 3:33 AM
- Celica ST202 w/ JDM 3S-GE 180HP (Special LE Subaru Blue steel paint!)
- A video of my car, before & after: Click here
post Sep 25, 2011 - 3:44 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Width of wheels and offset? Yours look about as sunken in as my current wheels and they are 7.5"w, ET45
June '12 COTM
'95 AT200
post Sep 25, 2011 - 3:52 AM
Iceman22
Joined Dec 16, '08
From Norway
The rims are only 7.5", the wheels are 215x40-R17.
post Sep 25, 2011 - 4:07 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (Iceman22 @ Sep 25, 2011 - 4:52 AM) *
Still need to know the offset, should be stamped on the inside of the rim somewhere. Also in the OP you asked about whether to do all or just front.. I'd say all wheels for a nice stance. Some people who don't do all wheels, just do the rears as the rear fenders sit a bit wider than the front. Furthermore, the spacers will likely (but not always) be different sizes, meaning front spacers will be smaller than the rear spacers (for example 25mm up front, 30mm in back). Hope I don't sound confusing.
post Sep 25, 2011 - 4:26 AM
HectortheRican
Joined Dec 26, '09
Since yours are 7.5" as well, I'd say it's a pretty good chance that you're sitting with ET45, because they look about as sunken in as mine. My advice would be, unless you absolutely adore those wheels, get a new set with a better offset. Your wheels will need big spacers to make them close to flush and it'll kill your wheel bearings.
If your wheels ARE ET45, you'll need 30mm worth of spacer in the front and 47mm worth of spacer in the rear to make them completely flush with the fenders. A lot of people are not into that, but those numbers give you an idea of what you'd need.
This post has been edited by HectortheRican: Sep 25, 2011 - 4:26 AM
June '12 COTM
'95 AT200
post Sep 25, 2011 - 4:37 AM
whatthe
Joined Aug 13, '08
From Australia
QUOTE (HectortheRican @ Sep 25, 2011 - 7:26 PM) *
great minds think alike
post Sep 25, 2011 - 4:40 AM
Iceman22
Joined Dec 16, '08
From Norway
Sorry forgot to mention, the ET is 40.
QUOTE (HectortheRican @ Sep 25, 2011 - 4:26 AM) *
A new set of wheels is not a option.
Do you still recomend 30mm in front, and 47-50mm in rear for ET40 ?
post Sep 25, 2011 - 2:33 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Iceman22 @ Sep 25, 2011 - 3:40 AM) *
The ideal "flush" offsets for a 7.5"w wheel are +15mm front, -2mm rear. So now you'll need 25mm up front and 42mm rear.
June '12 COTM
'95 AT200
post Sep 25, 2011 - 5:30 PM
Iceman22
Joined Dec 16, '08
From Norway
Ok thanks for the reply HectortheRican.
Any other here agree with hector or have any thoughts ?
post Sep 25, 2011 - 6:00 PM
Yes, I'll add. You also have the option of going in between. If you don't care to give up the wheels, settle for something like 20 in front and 25 in back, that should be doable and won't eat your bearings.
20 MM spacers all around, looking nice enough to me:
This post has been edited by SwissFerdi: Sep 25, 2011 - 6:03 PM
post Sep 25, 2011 - 11:07 PM
HectortheRican
Joined Dec 26, '09
QUOTE (SwissFerdi @ Sep 25, 2011 - 5:00 PM) *
x2. I was just giving the numbers for complete flushness, 20 or 25 mm spacers all around will still look very very good. Better, in fact, in most cases.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: February 13th, 2025 - 2:37 AM
