> Transmission Issues
post Sep 25, 2011 - 10:40 AM
barterj
Joined Aug 28, '08
From Woolwich, Maine
So....yesterday while driving around my transmission started making a clicking and clanking sound while moving. Then just before i got home it started to bind while clicking and clanking. I know my throw out bearing has been going for a while as it has been whining a while. All the gears seem to work fine.
What do you think is wrong, is it just that the throw out bearing is finally destroyed or is the whole transmission gone?
post Sep 26, 2011 - 7:53 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
may need a servicing. I think its just the bearing. have n oil change, if u see traces of metals in your oil, then it could b worse than wat i am thinking.
post Sep 26, 2011 - 12:07 PM
barterj
Joined Aug 28, '08
Okay, i thought about doing that as well, hopefully this weekend.
post Sep 26, 2011 - 2:17 PM
barterj
Joined Aug 28, '08
any other thoughts from anyone?
post Sep 26, 2011 - 9:50 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (barterj @ Sep 26, 2011 - 3:17 PM) *
Well mine did that about a year ago and I got it to work again by messing with the shifter. It lasted about 6 months then
I was 1 block from where I live and all hell broke loose. I could not shift the sound was loud and metal was flying. Turned out to be the clutch was cracked and the springs broke out and were flying around. Some other symptoms may be
Taking off in first gear you feel some shaking(probably because of worn cluth and flywheel) and a slight whine while engaging to 3rd or 4th.
throwout making noise when in neutral and clucth out.
I put in a new clutch and fly it set me back 8 big ones but got a new slave and tranny fluid of course and it works like brand new.
This post has been edited by xrav22: Sep 26, 2011 - 9:52 PM
post Oct 13, 2011 - 11:26 AM
KenP
Joined Oct 13, '11
From Eagle Lake, Maine
Okay hopefully someone can help me out. I have a 2002 Toyota Celica. It has a 5 speed manual transmission. I brought it to a mechanic and had some stuff checked. They told me that they could hear a clicking noise coming from the transmission and they said that they would schedule me for an appointment to change the oil in it. I'm putting MT 90 for the oil. I guess this is the best for this type of transmission. Today I was coming back from work and I could hear clicking coming from under the dash area. It dont do it in first or second. But when I shift to third, fourth and fifth it makes the noise. I need to know if this has happened to anyone else and what is the cause. Is it a bearing? Clutch? Or is it about to **** the bed?
This post has been edited by KenP: Oct 13, 2011 - 11:28 AM
post Oct 13, 2011 - 11:39 AM
mkernz22
Joined May 10, '10
From MA
there might be some people on here that know about the newer celica's but this forum is only for 94-99 celicas.
does it it constantly click though, or just do it when shifting gears?
post Oct 13, 2011 - 6:19 PM
KenP
Joined Oct 13, '11
Constant clicking once I am going down the road and have already shifted. I posted about my 2002 because I dunno where to find 2002 forums. I figured that they weren't that much different.
Lo-Fi Version Time is now: January 9th, 2025 - 2:33 AM
