> Washing engine bay?, how to?
post Sep 28, 2011 - 4:03 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
Well as title says, I want to pressure wash my engine bay but I'm kind of nervous to do so as I feel I will short something out. As far as I can think I would want to cover the air filter, disy, alternator, battery, fuse box...anything else I should be aware of?
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Sep 28, 2011 - 4:14 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
Do it on a hot day and leave it to dry in the sun for hours before trying to start.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Sep 28, 2011 - 4:18 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
Thanks Pilot, I know it's not a hard task but I have never done it so thought I would ask to double check =)
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Sep 28, 2011 - 9:15 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
whatever you do, dont hit the radiator or AC condenser with the pressure washer. it will fold the fins over in a heartbeat and kill its cooling properties
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 16, 2011 - 8:32 PM
j0ch0a94ST
Joined Sep 27, '07
From Raleigh, NC
I wouldn't advise it. I covered my electrics and am still trying to diagnose months later what exactly went wrong. So my advice is just wipe it down by hand to be safe
post Oct 16, 2011 - 8:44 PM
mkernz22
Joined May 10, '10
From MA
just use some simple green and a regular hose, works fine for me
post Oct 16, 2011 - 9:01 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
double post
This post has been edited by stephen_lee: Oct 16, 2011 - 9:11 PM
post Oct 16, 2011 - 9:10 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (stephen_lee @ Oct 16, 2011 - 9:01 PM) *
I have always pressure washed my engine bay... no issue. never covered anything. only watched out for the dizzy
whatever you do, when its still wet, spray EVERYTHING in the engine bay with armor all, dont wipe anything. when its dry, itll look beautiful
edit: typos... "P" wasnt working
post Oct 16, 2011 - 11:01 PM
6G96GT
Joined Jan 20, '08
From East Coast
I just pressure washed 'everything' - no protection whatsoever and I do it all the time. No probs since I've owned the car (2008). My car runs perfect and starts up every time.
post Oct 17, 2011 - 1:20 AM
matts94celica
Joined Apr 20, '11
From College Station, Tx
Nice stephen I love the checkered rachet strap holding the battery down;)
But just avoid electrical, dizzy, ect. And let it dry out before starting. I know I'm of no help but I'm trying.
-Matt
post Oct 17, 2011 - 2:37 AM
chacha
Joined Dec 29, '05
From So-Cal
I just use engine cleaner foam you find in an aerosol can at the auto store and water it down ..... try not to get electrical....and then i use my shop-vac and blower to blow out the water and let it dry with the hood open in the sun (during Summer where it is over 100 degrees here)
post Oct 17, 2011 - 8:51 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (matts94celica @ Oct 17, 2011 - 1:20 AM) *
-Matt
LOL every other tie down I used ended up breaking in hard corners.. cause I hit them HARD. This one shouldnt break.
post Oct 17, 2011 - 8:57 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
But when I wash the bay I do it like this:
-Go to a do it yourself car wash
-Leave the engine running, pop the hood
-Use the "degreaser setting" to spray the bay down(get the block, trans, firewall, battery, head, intake mani, AVOID the dizzy) The engine may misfire if you get the dizzy wet, BTW(if so, dont worrk, just avoid it more, this is why its running, the heat will dry it out faster). Get the wheels while you're at it. also give the bay a quick once over before you change steps.
-Use the "wax" setting and rinse off the bay. HI pressure everywhere except close to the dizzy
-Soak the bay down with armor all.
-Close hood
-Was car as normal.
post Oct 17, 2011 - 9:01 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Zero07 showed me this method. my engine bay started out HORRIBLY ugly, messy and what not. After a the first wash, it looked much better. Keep doing it, you will notice oil leaks, the grime will slowly disappear from the whole engine. Makes work on the engine much cleaner.
No joke I changed the head on my daily && my hands were as dirty as if I changed spark plugs on a regularly dirty engine.
post Oct 17, 2011 - 3:02 PM
jakesne
Joined Oct 2, '11
From Wilkes-Barre, PA
I wouldn't advise spraying water on a hot block or head, I've seen too many crack because of that
post Oct 17, 2011 - 4:13 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (jakesne @ Oct 17, 2011 - 3:02 PM) *
thats interesting... i know if you add cool water to a overheated engine that causes issues... but not water on a op temp engine...
Lo-Fi Version Time is now: February 18th, 2025 - 4:11 PM
