oil light |
oil light |
Sep 28, 2011 - 5:50 PM |
Enthusiast Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) |
I put a oil filter relocation kit on my 94 st and it has an oil light on...oils full. Filter is full after first crank. Oil pump works and the dip stick is showing full after I checked it 100 times. Why is my oil light on? I reset comps and it still on..help!!!
Sep 28, 2011 - 6:22 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Most likely the signal wire is grounding out...Does it go off at high RPMs?
Sep 28, 2011 - 6:48 PM |
Most likely the signal wire is grounding out...Does it go off at high RPMs? No its always on. But I drove it and after like 15 miles the engine bogged down a little (like 200 rpms) then leveled out it did that like 3 times then stopped but I went up to stop from 55 mph and it killed the engine once. Then no problems after that but still has light on. -------------------- |
Sep 28, 2011 - 6:57 PM |
did you put the hoses on backwards? its possible
Sep 28, 2011 - 8:09 PM |
I don't believe so but now my engine is tapping. I'm seriously pissed at this car..its full of oil and the pump is working. Is the bearings gone on my main? Ugh I'm just tired of this car messing up. Do the swivel ends go on the bypass adapter or filter adapter.
Sep 28, 2011 - 9:12 PM |
theres a reason that light usually comes on.
you have low oil pressure if the only change was a oil system mod, id shut the car off immediately and fix the issue, or revert to stock.. but sounds like youre too late -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Sep 28, 2011 - 9:33 PM |
So full engine rebuild? I'm serious considering selling it now if I wanted to drop money into a car I would have bought a mk3 supra it just needed an engine...fml
Sep 28, 2011 - 10:16 PM |
how about you get a gauge and see what your oil pressure actually is rather than guessing.
Sep 28, 2011 - 11:33 PM |
So full engine rebuild? I'm serious considering selling it now if I wanted to drop money into a car I would have bought a mk3 supra it just needed an engine...fml If you don't like rebuilding engines, dont get a mk3 supra.../story hahaha. I doubt your engine is dead, if you had low oil pressure youd get rod knock, which is obvious. |
Sep 29, 2011 - 9:04 AM |
I don't believe so but now my engine is tapping. I'm seriously pissed at this car..its full of oil and the pump is working. Is the bearings gone on my main? Ugh I'm just tired of this car messing up. Do the swivel ends go on the bypass adapter or filter adapter. So full engine rebuild? I'm serious considering selling it now if I wanted to drop money into a car I would have bought a mk3 supra it just needed an engine...fml If you don't like rebuilding engines, dont get a mk3 supra.../story hahaha. I doubt your engine is dead, if you had low oil pressure youd get rod knock, which is obvious. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Sep 29, 2011 - 10:21 AM |
yep you probably got the lines backwards so no oil pressure is going in the system. or you might have a blockage. but if its tapping then you more than likely spun a bearing.
Sep 29, 2011 - 1:37 PM |
Go check your lines, fix w.e. is screwed up. Then put in some heavier oil and prey. No it wont fix your issue but it MAY allow you to drive the engine a while(or sell it, lolol jk). Sorry for the rotten luck man! And just out of curiosity why would you putting an oil filter relocation kit on a 7afe?
And touche stephen This post has been edited by SupraKid: Sep 29, 2011 - 1:37 PM |
Sep 29, 2011 - 5:42 PM |
Well, your probably right on the spun bearing.
@Supra kid i was putting the kit on so i can do my down pipe for turbo. what luck that it had to happen day before turbo was going on . There is no noise from underneath on the bottom of the block. Talked to a guy that messed with my dads car and said the head is gone, so I'll be picking up a junkyard engine and rebuild the 7afe for my good turbo build >:) Ill probably be starting a build thread on the engine. Wish me the best of luck This post has been edited by matts94celica: Sep 29, 2011 - 6:04 PM -------------------- |
Sep 29, 2011 - 7:57 PM |
MANY toyotas have valvetrain noise, normal IMO
if it gets louder with rpms its in the bottom end. but even a minute of running(not @ idle) w/o oil pressure would make me nervous to turbo, or even to drive it much at all w/o a rebuild -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Sep 29, 2011 - 8:13 PM |
But just to make you feel better, we have a customer who drove about 15-20 miles with the oil light on on their 1MZ-FE Sienna. They parked at home, drove it about 5 miles to us for an oil change. I drained out some smoke and about 2 ounces of oil.
New filter, filled it up, they're still driving it. It's been months. -------------------- |
Sep 29, 2011 - 8:36 PM |
I'm going hunting for a 7afe tomorrow so I can soon have the celi up and running then rebuilding old engine with some goodies so it'll be ok I guess even tho I can't afford it:/
Lo-Fi Version | Time is now: January 10th, 2025 - 4:16 PM |
