Cooling unit: heater doesn't work., Blower works perfectly. |
Oct 1, 2011 - 7:02 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Everything works fine and the blowers blows perfectly but only cold air. The switch's motor doesn't work but I can switch it manually. The 2 prestone hoses get hot but the air in the car stays cold. (It's a Gt-Four model)
What could it be? This post has been edited by dudeofchaos: Oct 5, 2011 - 4:50 PM |
Oct 2, 2011 - 8:09 PM |
either your heater core is clogged, or the shut of valve not working. check under the hood, there is a little valve that moves when you switch to heat..
Oct 5, 2011 - 4:51 PM |
either your heater core is clogged, or the shut of valve not working. check under the hood, there is a little valve that moves when you switch to heat.. I looked and the shut off valve didn't move by itself so I moved it manually. The prestone hoses got hot but the temperature didn't rise. This post has been edited by dudeofchaos: Oct 5, 2011 - 4:52 PM |
Oct 8, 2011 - 11:00 PM |
clogged heater core, has it worked before?
Oct 10, 2011 - 11:35 PM |
Lo-Fi Version | Time is now: January 10th, 2025 - 4:15 AM |
