2 Pages V  < 1 2
> 5s intake manifold swaps
post Oct 13, 2011 - 8:42 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (Malhar95 @ Oct 12, 2011 - 11:46 PM) *
Doesn't nos damage the engine? How often can u use it?
Not if its set up properly. & As much often/fast as you fill the bottles I assume
post Oct 14, 2011 - 11:29 PM
Ted95
Joined Mar 8, '09
From Westport, MA
http://www.mr2.com/forums/check/Toyota-MR2...ome-advice.html
are you sure you want a N/A 5sfe build?
st205 powered ss3 coupe
post Oct 15, 2011 - 12:15 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
it does if its not respected, if you use something mild like a 50 shot you will be just fine. you can use it as long as you have juice in the bottle. with a wet kit you mix gas with nitrous, its much safer, the engine will run richer and not detonate. if you run a larger jet the mixture might still be safe, but its the cylinder pressures that kills the engine. these engine have a lower compression than the 2ZZ in the 7th gen celicas and we run 50-75 shots all day long racing. so you will be just fine
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 24th, 2024 - 12:24 AM
