3 Pages V   1 2 3 >
> 3s-gte rebuild
post Oct 6, 2011 - 3:41 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Hello!
I got 1994 st205 celica. now it's time to rebuild the engine. it started knock very bad. i think it's camshaft bearings.
The knock started when i was driving, i stop and the oil was wery low.
I need advice where to buy new parts. i'm from Finland.
I got the engine out and now i have a problem. i can't get the trans off the engine.
i think every bolt is off.
help please!
here is some pictures
intake side
exhaust side
post Oct 6, 2011 - 7:16 PM
bsamps4
Joined May 16, '10
From Raleigh
Problem #1
Your starter is still attached to the transmission. Those 2 bolts that hold the starter in also hold the transmission onto the engine.
Problem #2
The engine knock is likely not associated with your camshaft bearings, but likely something in the short block.
post Oct 6, 2011 - 10:18 PM
Neon90424
Joined Jan 19, '11
www.ebay.co.uk should have sellers that sell to europe and have plenty of celica stuff on there
post Oct 7, 2011 - 12:27 AM
Gt4Driver
Joined Nov 2, '06
From Finland
Ok. thanks guys.
need to remove the starter. then i can open my motor and see what is the problem.
post Oct 7, 2011 - 4:30 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (Gt4Driver @ Oct 7, 2011 - 7:27 AM) *
Ok. thanks guys.
First thing what I would is register here http://www.gt4oc.net/ and look if there is any good part seller for you. there ate a lot of traders and ST205 enthusiasts.
post Oct 7, 2011 - 6:22 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
i use to get my parts in malaysia. Always the best parts 4 the best price.
post Oct 10, 2011 - 1:50 PM
Gt4Driver
Joined Nov 2, '06
From Finland
post Oct 10, 2011 - 3:12 PM
Neon90424
Joined Jan 19, '11
looks like a clutch kit could do good for you...they arent that expensive...flywheel included its like 300$
post Oct 10, 2011 - 11:50 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Yes it looks like it's time to chance it smile.gif is there any difference between 205 and 185 clutch?
post Oct 11, 2011 - 6:40 AM
Neon90424
Joined Jan 19, '11
they are the same I believe
post Oct 11, 2011 - 8:03 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
a short list of which parts you are seaching for and we coulc help you way better wink.gif
greetz
KEEP COOL UNDER PRESSURE
post Oct 11, 2011 - 10:50 AM
Gt4Driver
Joined Nov 2, '06
From Finland
Hi. I need new clutch, main and rod bearings, bottom end gasget set, timing belt,
At this point don't know what else do i need.
post Oct 11, 2011 - 12:50 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
get the parts from toyota, here a link that helps
http://www.toyodiy.com/
do not though the main and big end bearings if they are well
greetz
post Oct 11, 2011 - 1:13 PM
Gt4Driver
Joined Nov 2, '06
From Finland
well. i think the bearings are bad, cause i was low oil and motor started to knock.
if i get parts from toyota Finland it's expensive.
post Oct 11, 2011 - 4:12 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
do not try to safe money, this can couse the next problem or a damaged engine again
i would prove to buy a used good working engine, possible the cheapest way
greetz
This post has been edited by Sunny: Oct 11, 2011 - 4:13 PM
post Oct 11, 2011 - 5:17 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the knock is defiantly from the crank bearings. there are no cam bearings. keep posting pics of your rebuild. i wrote a good thread on rebuilding the 7A-FE you can use it for refrence
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 16, 2011 - 11:04 AM
Gt4Driver
Joined Nov 2, '06
From Finland
hello. it seems to be my 3 cylinder rod bearing is bad.
do i need to chance all four bearings? or is it good to chance only that what is gone bad?
post Oct 16, 2011 - 12:51 PM
Neon90424
Joined Jan 19, '11
they sell all 4 together and its not that expensive around 100$ give or take, The biggie is that once you open that engine you are paying the mechanic to basically take everything apart and put it back together might as well have new bearings in there...ARP bolts etc .
Just For example when i opened my engine up for a dead piston ring causing too much blowby I swapped the pistons out for forgies, forged rods and did all the bearings both main and rod bearings with some nice ACL race bearings
This post has been edited by Neon90424: Oct 16, 2011 - 12:53 PM
post Oct 16, 2011 - 3:50 PM
bsamps4
Joined May 16, '10
From Raleigh
It would be crazy to not replace all bearings! You should likely take the crank, rods, and pistons to a machine shop to make sure that everything is ok to go back in. ARP hardware isnt a bad idea, but will require additional machininh for proper fitment under torque load. Never go cheap on this type of thing. You should do as much as possible while you have the opportunity.
post Oct 17, 2011 - 1:54 PM
Gt4Driver
Joined Nov 2, '06
From Finland
ok. So im gonna replace all bearings.
In toyodiy main bearings there is like 10 different mark and no. like mark 1, no.3 toyodiy
and acl there is only std, .025, .25, .50 acl
So do i just order acl std
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: February 17th, 2025 - 5:43 AM
