3 Pages V  < 1 2 3
> 3s-gte rebuild
post Nov 15, 2011 - 9:36 AM
bsamps4
Joined May 16, '10
From Raleigh
No, it needs to click in all the way. The transmission seal only works with axles that are pushed all the way in. Anything less, and your transmission will likely leak, and let in dirt.
post Nov 15, 2011 - 9:42 AM
Gt4Driver
Joined Nov 2, '06
From Finland
So do i just need to hammer it on?
The other side clicked on very easy.
This post has been edited by Gt4Driver: Nov 15, 2011 - 9:44 AM
post Nov 15, 2011 - 2:42 PM
rave2n
Joined May 29, '09
From Gainesville, FL
I had to tap mine in with a deadblow to an end of the CV joint. Don't want to damage the internals. Timing side is the long shaft right? if so that is the one I had to tap in, the other was easy.
Took a few good whacks, but once you hear the lock ring click, its in.
Was on a ST trannie, but I assume same concept.
post Nov 15, 2011 - 3:51 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Oil sanwich plate install for oil pressure gauge and other.
post Nov 15, 2011 - 4:21 PM
Neon90424
Joined Jan 19, '11
my mechanic was preocupied by the oil press sensor when he put it in the sandwich plate...he said that when turning the wheel might hit it...just a heads up
post Nov 16, 2011 - 1:05 AM
Gt4Driver
Joined Nov 2, '06
From Finland
post Nov 16, 2011 - 3:41 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Been hammering it all day.
post Nov 16, 2011 - 4:06 PM
bsamps4
Joined May 16, '10
From Raleigh
Any way you could pull it out and take a pick of what the end looks like? May be damaged or something. Probably worth another opinion.
post Nov 16, 2011 - 4:14 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Ok. i'll take a pick tomorrow, now i need to go to sleep.
post Nov 17, 2011 - 4:49 PM
Gt4Driver
Joined Nov 2, '06
From Finland
it's in! just take it off and put it back. snap in pretty easy. Don't know what was wrong earlier. confused.gif
Maybe sunday i'll fire it up.
post Nov 20, 2011 - 4:19 AM
Gt4Driver
Joined Nov 2, '06
From Finland
Ok. It's time to fire it up kindasad.gif Hope everything is okay.
post Nov 20, 2011 - 7:54 AM
Gt4Driver
Joined Nov 2, '06
From Finland
No it wont start. starter just klicks.
post Nov 20, 2011 - 9:33 AM
Gt4Driver
Joined Nov 2, '06
From Finland
I hammered my starter and it starts to work
post Nov 20, 2011 - 9:44 AM
Neon90424
Joined Jan 19, '11
sounds like a new starter is in order...
post Nov 20, 2011 - 11:20 AM
Gt4Driver
Joined Nov 2, '06
From Finland
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 27th, 2024 - 4:13 AM
