just drove 1/3 across the US; now engine sounds bad!, engine noise |
Oct 6, 2011 - 4:50 PM |
Enthusiast Joined Feb 19, '05 From Indianapolis Currently Offline Reputation: 0 (0%) |
So I'm not having any issues, yet (knock on wood) with my 95' celi gt but... yesterday I drove like 750 miles from Indiana to Connecticut in it. After letting it sit overnight, the engine sounds like a prop plane, much deeper than it ever had. It sounds like a tank when I accelerate! I changed the oil before I left, even put new front brakes in. I checked the fluids and the only one that looks a bit low is the engine coolant.
I'm concerned it wont make it for the return trip so I want to be sure that I can do anything I need to until I make that trip next week. Any suggestions? -------------------- |
Oct 6, 2011 - 6:11 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Sure it aint just an exhaust issue? Usually having deeper sounding engine is exhaust issue related. Did it burn any oil? Coolant clean still? Gauges all read fine? Probably isn't a prob with the engine.
Oct 6, 2011 - 8:26 PM |
Enthusiast Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
Check your oil level.
-------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Oct 7, 2011 - 3:41 AM |
swap engine.
Oct 7, 2011 - 6:19 AM |
Enthusiast Joined Jul 14, '08 From Mauritius Currently Offline Reputation: 0 (0%) |
In my opinion it could be your clutch or simply a bearing....or transfer box? differential? Surely a mechanical issue. No rattling??
Oct 7, 2011 - 7:31 AM |
sounds like you have a break in the exhaust before the muffler. start the car, put your hand over the exhaust outlet to plug it, does it build pressure? I bet it doesn't at all and the rumble changes tone slightly.
Oct 7, 2011 - 7:53 AM |
I drove it today and it still didn't sound good. My friend whom I am staying with said he heard me pull up even though he was in the shower simply from the sound of the exhaust. Also, I went over a bump and it sounded like something hit on the ground! I'm going to check the exhaust pipes when I get back out there. The car just feels like it rides a little rougher too.
oh and the oil level was still topped off. This post has been edited by Terzin1: Oct 7, 2011 - 7:54 AM -------------------- |
Oct 7, 2011 - 8:16 AM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
my bet is you broke your exhaust at the flex pipe maybe...happened to me...
Oct 7, 2011 - 8:30 AM |
x3
I've got a similar "booming" sound with certain acceleration, coming from around my firewall. I'm betting exhaust leak at the flex pipe for myself as well. A clunking sound would confirm that theory, seeing as pipe should be bangin' around down there. This post has been edited by SwissFerdi: Oct 7, 2011 - 8:34 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Oct 7, 2011 - 3:26 PM |
so I looked under my car today and low and behold I found this lovely scene. (click on the link, I dunno how to add pics to this forum, its impossible apparently)
http://www.flickr.com/photos/68384144@N03/.../in/photostream How the heck am I gonna fix this with no tools and no idea where the nearest autozone are? This post has been edited by Terzin1: Oct 7, 2011 - 3:31 PM -------------------- |
Oct 7, 2011 - 3:58 PM |
Enthusiast Joined Oct 7, '10 Currently Offline Reputation: 3 (100%) |
Junkyard?? Idk man, I don't think this is an issue that is going to cause problems (I may be wrong) it seems like more of an annoyance.
-Nate |
Oct 7, 2011 - 4:43 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
I guess the noice must be bad but best thing you can do it try to make it hold with high temp muffler tape and fix it when you get home.
Oct 7, 2011 - 5:27 PM |
I remember when that happened to mine! lmao came off the dirt after a little off roading and hit a little bump and heard this big wooohhh wooohh type sound. looked under my car after I got to the store with my buddy and mine broke at that same exact spot. I loved the sound of it, especially the small little popping sounds when you let off the gas! still does it a little bit with my new exhaust on since I have no cats now and only have one resonator.
Since it's a 1995, you can just have an exhaust place put new flanges on it and throw a pipe in place of the cat (would be the cheapest solution). This post has been edited by mkernz22: Oct 7, 2011 - 5:28 PM |
Oct 7, 2011 - 7:21 PM |
Lmaoo dude just drive it to the nearest muffler shop on the way and str8 pipe that @!*!@$
Oct 8, 2011 - 11:58 AM |
That sucks. I thought it was an exhaust issue. You don't 'have' to get that fixed man. I would simply find/buy something to tie both pieces up to get them off the road and to get them to stay put - not to connect them. Drive it home dude and when you get home, fix it there.
This post has been edited by 6G96GT: Oct 8, 2011 - 11:58 AM |
Oct 8, 2011 - 2:35 PM |
Boso pipes. Be a man.
Oct 11, 2011 - 3:26 AM |
I couldn't find any tape to try and hold the pieces together for the trip back so I just said to hell with it and just now returned to Indiana without fixing anything. For a while when I would go over bumps or potholes I would hear the pipes clang against the road. I hit a particularly large pot hole and hear a giant bang and then nothing more. I'm now missing a section of piping which undoubtably flew off somewhere on i80 in PA!
Oct 11, 2011 - 6:26 AM |
lol weightloss 101 drag it and lose it lmao
Oct 11, 2011 - 1:42 PM |
Time for a custom exhaust! A lot of exhaust shops will install a perf. exhaust cheap at least cat back for around $200 installed. Check into it.
Oct 12, 2011 - 12:39 PM |
Time for a custom exhaust! A lot of exhaust shops will install a perf. exhaust cheap at least cat back for around $200 installed. Check into it. I will, whats the differences in exhaust types? I know not much about them. -------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 4:25 AM |
