> idea for a low buck coilovers, wanna see if anyone else thinks this could work
post Oct 9, 2011 - 3:35 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok this is my idea I haven't hitting the parts to try it yet but it make sence in my head
could I use a set of front struts from a civic since there basically just a cartage an the cut the bottom half off the factory celica strut to make the sleeve for the cartage
it sounds like a good low buck setup to me since honda parts are cheap an they have the right perch for coilovers
any thoughts comment would be great
94 st hatch my daily driver
n
post Oct 10, 2011 - 2:26 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
I've been looking into this setup on superstrut suspension only because no company makes good racing coilovers for superstrut equipped vehicles.
Honestly it would take trial and to get a setup like this using different parts from different companys. I've looked and looked but no company makes struts a little bit shorter than our stock suspension. They are either too long or too short. Our Mcpherson geometry hinders us from making our own coilovers.
Just buy Megan coilovers for $950 and be done with it. Trust me I've looked and looked all over the place calling just about every suspension company here in the USA and its gotten me no where. There is a company over in malaysia that does custom coilovers but they will run you over $1,500 easily and are meant for racing setups...
post Oct 10, 2011 - 9:56 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok well like I said it was an idea
I might still grab a couple junk shocks an try it out an see Wat happens
n
post Oct 10, 2011 - 10:07 AM
mkernz22
Joined May 10, '10
From MA
go for it man! it doesn't hurt to try something different
This post has been edited by mkernz22: Oct 10, 2011 - 10:07 AM
post Oct 10, 2011 - 11:28 AM
drumbum
Joined Nov 29, '09
From Milwaukee
BC coilovers man... Best coilovers in that price range ... Definately worth the 995... Comparable to higher end coilovers
Weekend Warrior-----1998 Celica GT: White
Daily Driver----------1997 Celica GT: Blurple
post Oct 10, 2011 - 11:52 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok does anyone see a reason why this couldn't work
if it does I could have as little as maybe 300 bucks
I know they wont predominantly as good as the high end stuff but it should get the job done
n
post Oct 10, 2011 - 1:08 PM
BonzaiCelica
Joined Apr 24, '08
you can try all you'd like but the main thing if finding a shock thats the same height as the trd coilover inserts in which they don't exist. atleast not here in america.
megan coilovers/same as bc coilovers besides the spring rates allow for full adjust-ability and the best price range without having to go through the headeache of finding parts for your custom setup.
post Oct 10, 2011 - 1:19 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ill try to gather the parts to make atleast one to see if it can be done this weekend
n
post Oct 10, 2011 - 7:04 PM
Culpable04
Joined Apr 17, '06
From New Jersey
do some reading about Suspension Geometry, dont just put parts together that will bolt up, you need to make sure you keep the stock geometry or the car will handle like total cr@p
as long as you make it the right length / angles, is a good idea, you can weld a piece of threaded pipe to make up for a shorter shock and bring it to the right length, and use the threaded pipe to adjust the coilover spinning the whole assembly to keep the rebound
post Oct 10, 2011 - 7:19 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
thanks for the tips an the threaded pipe idea is a good one
im planning on using the celica top cap an the bottom of the strut for mounting them in hopes that ill br able to stay at the same stock specs as the stock strut
n
post Oct 13, 2011 - 7:31 PM
trdproven
Joined Aug 2, '05
From Guam
seems like a lot of hassle rather than just paying the one that fits your car.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 13, 2011 - 9:18 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (trdproven @ Oct 13, 2011 - 8:31 PM) *
your probably right but that part of the fun if working on cars is to try to do somethimg new
if it doesn't work oh well at least I tryed an I learn alil more about how my car works
n
Lo-Fi Version Time is now: November 28th, 2024 - 12:43 AM
