> LED climate control
post Oct 14, 2011 - 10:26 PM
Sloo94GT
Joined Oct 8, '11
From Manassas VA
Has anyone put LED's in their climate control, if so what size LED's did you use and what resistors did you use?
post Oct 14, 2011 - 10:48 PM
cheela
Joined Feb 2, '07
From Berlin, WI
post Oct 14, 2011 - 11:45 PM
spy00005
Joined May 15, '09
From yonkers, NY
http://www.6gc.net/forums/index.php?showtopic=61249
http://www.6gc.net/forums/index.php?showtopic=25583&st=0
look in the stickies!!!
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post Oct 15, 2011 - 3:29 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
X2 on the spree kit.led's are exactly what you want and in several colors+ it's always nice helping out a fellow 6gc'r
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Oct 16, 2011 - 6:34 PM
Spree
Joined Mar 25, '11
From West London
Thanks for the plug guys. :-)
I supply smd led's in your choice of color that you swap with the standard bulbs into the standard holders so no messing about with soldering and a good result.
www.SpreeLED.com Facebook Youtube
SMD LED CONVERSIONS FOR ALL TOYOTA CELICA GEN 6 - DASH - COURTESY LIGHTS - SIDELIGHTS - LICENCE PLATE BULBS - BRAKE LIGHTS
post Nov 7, 2011 - 2:18 AM
solidxsnake
Joined Apr 20, '09
http://www.youtube.com/watch?v=fcVch3lp45I&feature=feedu
That's the setup in my 2002 Corolla. For the climate cluster, I used 9 LEDs total:
-Around the temp knob there are 2 blue LEDs (rated 3.2v each) and 3 red LEDs (rated 2.1v each).
-Around the fan knob there are two white LEDs, and around the vent selector there are another two white LEDs (all white LEDs rated 3.2v).
These two branches of resistors are hooked up to the +VCC source that the original bulbs hook up to (observe polarity, check with a DMM), with a 100-ohm resistor in series with both branches to limit current in case battery voltage jumps above 12v (as happens when the car is running).
The AC, defrost and recirculate buttons all have their own LEDs, one white to light it (with 3.2v white LEDs, I used the single LED and a 560ohm resistor to hook up a single LED to a bulb power source) and a red as an indicator.
~Moving on to a 2002 Corolla S~
R.I.P Tom Celica - 1994-2010
post Nov 7, 2011 - 5:58 PM
trdproven
Joined Aug 2, '05
From Guam
looks pretty good for non-soldered.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 7, 2011 - 6:11 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Spree, do I have to solder leds on the cc unit?
God made man....
Everything else...
Made in China
post Nov 7, 2011 - 6:18 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (nics @ Nov 7, 2011 - 6:11 PM) *
Certainly not! ;-)
The LED's I supply are threaded into the standard bulb holders and refitted.
post Nov 7, 2011 - 6:51 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
I see. The indicators are the ones that need to be soldered and your kit doesn't include that.
I was thinking of getting the gauge cluster again because the SMD LEDs from ebay that I got has a greenish tinge on the speedometer.
God made man....
Everything else...
Made in China
post Nov 7, 2011 - 7:39 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (nics @ Nov 7, 2011 - 6:51 PM) *
That is correct. Its the backlighting that is covered in my kit.
Are you saying that the blue led's you got on ebay for the speedometer are greenish? i have seen that before.
The ones I have in stock now are very blue. More blue then the ones I used to get. I'm in the process of swapping the bulbs over in my dash now actually.
This post has been edited by Spree: Nov 7, 2011 - 7:40 PM
post Nov 8, 2011 - 3:38 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Spree @ Nov 7, 2011 - 4:39 PM) *
Spree, I actually have the white leds
It isn't as bright as the ones that you sell and has the green tinge mixed with the white.
God made man....
Everything else...
Made in China
post Nov 8, 2011 - 7:40 AM
Spree
Joined Mar 25, '11
From West London
I would be interested to see what your bulbs look like. If they use SMD's as you say then I doubt mine would be any different actually unless the SMD's in yours are dim for some reason.
I have found some variation in the plastics used for the instrument clusters that can cause that green tint. Some clusters come up really well and some don't....
The cluster in my JDM ST205 for instance is of the greenish variety and white bulbs look OK but never truly pop.
This is not a problem with the stronger colours like red, blue and green.
One area that my bulbs do help though is that I don't supply them glued into the bases so that they can be removed and fitted directly to the bulb holders.
This allows them to sit further away and light the cluster more evenly. This is mainly useful the middle speedo section as this causes them middle needle to light up much brighter and give a more pleasing look to the whole thing.
So a quick option may be to see if you can prize your bulbs out of the bases if they are not glued in too tightly (if only for the middle bulb, it doesn't make such a drastic difference on the other two) so you can at least get a better lit speedo needle.
You then just bend out the pins, slot the bulb into the holder and then loop the wires under the contacts. You may need to then trim off the excess wire. Just make sure that the two wires are not touching under the bulb before you refit.
This post has been edited by Spree: Nov 8, 2011 - 7:48 AM
post Nov 8, 2011 - 6:16 PM
richee3
Joined Jun 29, '08
From Denver
The gauges are tinted green because the back of the gauge faces are painted green. To fix that, you actually need to remove the gauge faces and sand the back of the numbers down. Otherwise, white LED's will always turn out with a greenish tinge in the gauge cluster. Colors like red and blue aren't nearly as affected by the greenish tinge as white.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 8, 2011 - 6:40 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (richee3 @ Nov 8, 2011 - 6:16 PM) *
Not all cars have this though. And the type of plastic does vary too. I will have to have another look at the back of my gauge faces though next time I'm messing about with them as a red needle kit is on the cards. That would be a good though if its just a green film on the back as that can at least be fixed.
There is not any green in these for instance.
These also came up very white without any sanding or anything although the photo is on a bit of a long exposure.
This post has been edited by Spree: Nov 8, 2011 - 6:45 PM
post Nov 9, 2011 - 4:57 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
I will try to get a pic of the actual leds. I have some spares in the car.
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: January 9th, 2025 - 5:19 PM
