> battery light on, comes and goes
post Oct 17, 2011 - 3:12 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
hello peeps!
So last Friday, I drove down to SoCal and after 420 miles, battery light came on. I pulled over, turned off the car and started it again, battery light came off. Then after driving another 25 miles, it came on again. And then I did the same thing, turn off and on the car. Worked the 2nd time! I got to my destination which is 15 miles more. Parked the car, called it a day.
After 12 hrs, started the car and viola, battery light remained on. I took it to autozone to have my battery and alternator tested. Autozone charged the battery first because it was 71% only. While in diagnosis, the guy made me start the car and miraculously the light wasn't on. The battery and alternator checked out ok.
So I decided to take the car for a spin, about 10 miles of driving light came in again! I pulled over, did my trick and it work. On my way back to my apartment, it came on again but when I exited the freeway, I went on a stoplight and when it turned green, battery light went away! I went to my parents house which is about 15 miles and back, battery light didn't come on.
Is my alternator going bad or my battery?
Are there other ways to test my alternator?
Is it possible that the belt could be the culprit? -Belt looks ok and tension seems right
What other things do I need to look at?
note: driving ~70mph when the battery light came on (driving to my parents' house ~70mph battery light didn't come on).
Need help to figure this out and fix it. Thanks
God made man....
Everything else...
Made in China
post Oct 17, 2011 - 6:22 AM
richee3
Joined Jun 29, '08
From Denver
Battery light is the alternator. The alt is probably going bad. If the light wasn't on when Autozone tested the alternator, it makes sense that it would look good when they tested it. It's a strange problem for sure. I doubt if it's belt related or you probably wouldn't have a/c either.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 17, 2011 - 12:02 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
check the wiring going to the alt. esp the 3pin connector.. id bet its loose.
either way clean up the 10mm post on the alt.
post Oct 17, 2011 - 1:08 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
checked the wiring, it's still intact.
God made man....
Everything else...
Made in China
post Oct 17, 2011 - 2:51 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (nics @ Oct 17, 2011 - 2:08 PM) *
Alt going out, an old car I had went for weeks with light on, then it just died. The bushings worn or diodes failing slowly.
post Oct 17, 2011 - 3:26 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
what brand should I get? How reliable is duralast from autozone?
God made man....
Everything else...
Made in China
post Oct 17, 2011 - 4:15 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
ALL aftermarket parts stores are the 70a version... that said i have one on my auto daily and its OKAY. my system full blast, high beams, and fogs dip it below 13v while driving, though... so in my case I need a higher output alt, or DUAL.
post Oct 17, 2011 - 10:04 PM
trdproven
Joined Aug 2, '05
From Guam
i saw that battery light come on, in a 5sfe camry, it was definitely the alternator on that one, so it is an idea to check it out.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 18, 2011 - 6:34 AM
richee3
Joined Jun 29, '08
From Denver
Why buy a new one? Just get the factory alt rebuilt. It's like $50 and I trust it more than cheap aftermarket alternators.
1998 Celica GT-
BEAMS Swapped.
post Oct 18, 2011 - 8:39 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (richee3 @ Oct 18, 2011 - 6:34 AM) *
yeah. Toyota rebuilt alt are comparable in PRICE to parts stores alts.
post Oct 18, 2011 - 9:27 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
bought one, installed, drove 500 miles on it. I needed it to get back to norcal. Costs me $140 +$20 for the belt.
where do I get the toyota rebuilt alt? Dealer??
God made man....
Everything else...
Made in China
post Oct 18, 2011 - 10:40 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah
the dealer
post Oct 18, 2011 - 11:25 AM
trdproven
Joined Aug 2, '05
From Guam
like what stephen said, on my celi, the alternator harness got brittle and got loose, and the wires werent holding on tightly like dangling wires, i found this when i had a notion it cannot be the alternator so I pulled the wire loom back and there it was the plastic harness all falling apart.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 18, 2011 - 4:40 PM
richee3
Joined Jun 29, '08
From Denver
Nah, I didn't mean go buy a rebuilt Toyota alternator. I meant get the one you have rebuilt. I had mine done, cost $50, better than new.
1998 Celica GT-
BEAMS Swapped.
post Oct 18, 2011 - 7:29 PM
trdproven
Joined Aug 2, '05
From Guam
almost all if not all things from napa are rebuilt at least in my area.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 18, 2011 - 10:34 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (stephen_lee @ Oct 18, 2011 - 8:40 AM) *
yeah
the dealer
I didn't had a chance to check my local dealership but I looked it up on 1sttoyotaparts and its like $150. It's a rebuilt alternator.
QUOTE (trdproven @ Oct 18, 2011 - 9:25 AM) *
I noticed that too that my harness is kinda crusty.
QUOTE (richee3 @ Oct 18, 2011 - 2:40 PM) *
Oh I see. Well I didn't know how long would it take to rebuilt it and I was running out of time. Now I know!!
God made man....
Everything else...
Made in China
post Oct 19, 2011 - 2:06 AM
trdproven
Joined Aug 2, '05
From Guam
if you need a replacement harness just go to a junkyard, take a sample of yours, or a picture, or remember the type of harness, and at the junkyard, you can look for any compatible toyota that is the same harness type, i know for sure that the mid 90s corolla is the same.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: February 21st, 2025 - 12:59 PM
