I broke my Supra racing yesterday |
Oct 17, 2011 - 5:45 PM |
Well on my quest for a 10 second pass the engine finally gave out on me. I had a good launch, 1.7 60' and I was doing 100 MPH in 7 seconds in the 1/8th then POOF!!! something let go. I coasted through the traps at 11.3 @ 127 MPH. After getting her home and pulling the plugs, # 5 and 6 were both covered in oil. I busted 2 pistons well here is my excuse to build it up! I was pushing 30 psi and squeezing a 75 shot of juice.
I will document the rebuild like all my other builds and post here so stay tuned for lots of pics! -------------------- 2001 Celica GT-S Turbo
Oct 17, 2011 - 6:31 PM |
This could be the most exciting thread in recent 6gc history.
Oct 17, 2011 - 6:38 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
This could be the most exciting thread in recent 6gc history. x2 Definitely looking forward to the 2JZ build thread. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Oct 17, 2011 - 7:45 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
30 psi, with a 75 shot..on a stock engine...Damn the 2jz is beastly haha.GL jeff.
well i popped 2 pistons at the track today so im going to rebuild. already settled on eagle rods. now im looking into pistons. who carries .020 wiseco pistons? or what are the best "budget" pistons to get? next question. i see MVP and other vendors carry complete bearing sets, well im not getting over or under sized but how will i know exactly what size to get. i haven't torn into a 2JZ yet but on 3S-GTE or 5S-FE or 2ZZ and 1ZZ there is a number on the crank and a number on the block to tell you what size bearing to get. i guess im a little confused on how this works out on a 2JZ. i will be upgrading to a 272 intake and 264 exhaust cam. do i really need new springs or can i just get away with upgrading to the 1ZZ-FE buckets? As stated before, budget and best never fit together haha. What kinda power goals are you going for? If your 100% sure your crank has never been machined than just get a STD set of bearings, but if not then just get the ol micrometer out and check!Also ive never heard anything but good things about real OEM toyota standard bearings. When you say "busted" you mean chipped or cracked or what? Why not do new springs while you are in there? I mean compared to eagle rods and .20 over pistons they wont be to expensive. This post has been edited by SupraKid: Oct 17, 2011 - 8:00 PM |
Oct 21, 2011 - 10:07 AM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
Do it right the first time my dude! go all out on her, may take a while but it will be worth it goodluck!
-------------------- st205 powered ss3 coupe
Oct 27, 2011 - 12:20 AM |
well some parts have arrived. I bought a set of GSC Camshafts, OEM gasket kit, new oil pump, and ARP mains.
Nov 3, 2011 - 9:03 AM |
Quick update, I have ordered all the parts i need. So far i have spend $3020.00 and i still need to buy bearings and have the machine work done. I ended up getting Eagle rods, JE pistons (.020 over), GSC 274 cams, new oil pump, full gasket kit, BC valve springs, titanium retainers, 1ZZ-FE buckets.
Nov 3, 2011 - 9:50 AM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
1000 hp Supra GOGOGOGO!
Nov 3, 2011 - 1:16 PM |
Nov 3, 2011 - 4:45 PM |
I'm pretty sure I just had an orgasm. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Nov 30, 2011 - 10:42 PM |
all my parts are here, i just got a lead on a spare block so i can build my engine and just swap them out.
JE Pistons .020 over New Oil Pump ARP Mains and Crower springs with titanium retainers Eagle Rods New OEM Gasket Kit GSC Stage 2 cams This post has been edited by Smaay: Nov 30, 2011 - 10:45 PM -------------------- 2001 Celica GT-S Turbo
Dec 1, 2011 - 8:59 AM |
giggity giggity goo
Dec 1, 2011 - 9:09 AM |
Dec 1, 2011 - 9:58 AM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
In for the resulting awesomeness.
-------------------- Has no more Celicas
Dec 1, 2011 - 4:14 PM |
im in the process of moving, once i get in the new place, ill start tearing into it. just look for updates
Dec 1, 2011 - 9:04 PM |
Supra > place to live.
Dec 7, 2011 - 12:00 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
I'm pretty sure I just had an orgasm. As soon as I opened the page and saw the two turbos staring at me, I got chills. Legit. God that's scary! 376cubic inch V8?! 10,000 RPMS?! AND CAN HANDLE 50LBS OF BOOST? ****. This post has been edited by RabidTRD: Dec 7, 2011 - 12:00 PM -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jan 5, 2012 - 4:17 PM |
started moving into my new house. once everything gets settled, ill tear into the Supra
Jan 6, 2012 - 10:19 PM |
Enthusiast Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
At first I was like, "This is going to be a tragic thread" then I was like stan in that picture above lol
Here's to everything going well on your ride and your new house! Good luck! -------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
Jan 14, 2012 - 9:42 PM |
yeah luckily it was just the engine,
yeah luckily it was just the engine, -------------------- 2001 Celica GT-S Turbo
Lo-Fi Version | Time is now: November 29th, 2024 - 5:17 AM |
