> Boost surging between 11-13psi, Boost set at the 13psi with boost controller but falling back
post Oct 20, 2011 - 12:32 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
I got a go fast bits boost controller, set at 13psi, at full acceleration it goes up to 13psi but the falls and rises back to 13psi rapidly, I can feel the acceleration jumping and falling back accordingly, Spikestop is off on the boost controller, and when I turn off the controller and run wastegate 10psi it doesn't jump around at all, what could cause this? On a cold night it tends to be better behaved.
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Oct 20, 2011 - 2:14 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
did you block off TVSV?
post Oct 20, 2011 - 2:26 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
your wastegate settings are off, i had the same issue with my truboost
2001 Solar yellow Lexus IS300
post Oct 20, 2011 - 6:09 PM
cax_11
Joined Aug 15, '10
QUOTE (purplegt4 @ Oct 20, 2011 - 2:14 PM) *
TVSV disconnected and lines are blocks off.
QUOTE (96stgreendemon @ Oct 20, 2011 - 2:26 PM) *
Explain to me, I have stock internal wastegate, and set the boost by increasing duty cycle slowly until I reach 13psi.
Nevis, West Indies
post Oct 20, 2011 - 6:20 PM
96stgreendemon
Joined Oct 7, '09
Should have a way to input the stock wastegate spring pressure, ive found that mine on the 3rd gen is around 6.5lbs pressure. then that feeds off the duty cycle
post Oct 30, 2011 - 9:24 PM
cax_11
Joined Aug 15, '10
QUOTE (96stgreendemon @ Oct 20, 2011 - 6:20 PM) *
nope, my controller is not that complexed, its has these three to adjust..Duty Cycle..Gain..Spike Stop
Nevis, West Indies
Lo-Fi Version Time is now: November 24th, 2024 - 1:29 AM
