> st205 3sgte wiring into st204 body?, I've searched and searched..
post Oct 20, 2011 - 3:56 PM
justincapps94
Joined Oct 14, '11
From gig harbor wa
I'm beginning the swap and I'm not sure what needs to happen as far as wiring goes when I go to install.
So here are my questions:
1: Should I pull both harnesses, and get ahold of someone to wire them together?
or
2: Is is possible to simply cut a hole in the firewall to feed the harness from the 3sgte to the ecu (3sgte ecu of course) and would that work with the rest of the car?
Like I said, I've searched and haven't been able to find a solid answer.
Here's a teaser I took a couple days ago.
smile.gif plenty more pics coming soon. thank you!
post Oct 20, 2011 - 4:36 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (justincapps94 @ Oct 20, 2011 - 3:56 PM) *
or
1-its your choice but for myself , no. dont pull out the harnesse, cut your hole in firewall before u put the engine in, or you can extend the wire, the only thing is the ea1 plug , do search, and make your choice from there, some ppl do that diffentetly and its also works
2- yes
post Oct 20, 2011 - 5:26 PM
justincapps94
Joined Oct 14, '11
From gig harbor wa
Shoot... I alrighty have the harness out for the most part...
but thank you for the answer!
This post has been edited by justincapps94: Oct 20, 2011 - 5:28 PM
post Oct 20, 2011 - 11:12 PM
Ted95
Joined Mar 8, '09
From Westport, MA
its alot easier to cut a hole in the bottom of the fire wall rather then extending every single wire in the harness.
this thread will show you what you have to do to your harness to get it swapped properly your self.
http://www.6gc.net/forums/index.php?showto...3105&st=140
its a VERY detailed thread that will answer just about any question you might have along the way, look through it a couple times it will help. and there are plenty of guys on here who can help as well, myself included. goodluck dude!
st205 powered ss3 coupe
post Oct 21, 2011 - 1:09 AM
justincapps94
Joined Oct 14, '11
From gig harbor wa
Thank you needles and ted, this is helping so much. I feel completely confident about the wiring!
post Oct 22, 2011 - 2:09 PM
Needles
Joined Nov 18, '10
From montreal
post Oct 22, 2011 - 5:18 PM
justincapps94
Joined Oct 14, '11
From gig harbor wa
Oops needles your right, I'm at work but tonight I'm gunna start a build thread
Lo-Fi Version Time is now: February 20th, 2025 - 1:52 PM
