what do i need to install the throtle body off toyota caldina gt4 |
Oct 26, 2011 - 6:53 AM |
Enthusiast Joined Sep 2, '11 From cyprus Currently Offline Reputation: 0 (0%) |
if any one know how much ( mm ) is the throtle body of toyota celica st205 and how much ( mm ) is the toyota caldina gt please tell me
I read from some where i can install the throtle body of toyota caldina gt4 in st205 celica is that true?? I must to know something before i install it ?? |
Oct 26, 2011 - 10:00 AM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
the ST205 throttle body is ~60mm, the caldina one is the same design which means also ~60mm no, the caldina one is not plug&play, the mechanism rotates in the opposite direction, the sensor is different but the big problem is the ISCV ST205= the channel of the valve is in the middle of the TB ST215= the channel of the valve is some mm left of the middle people often gets told that the caldina TB is bigger in diameter but this in not true, both butterly to housing alignments are identical hope it helps greetz -------------------- |
Oct 26, 2011 - 10:16 AM |
Enthusiast Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) |
Completely true good stuff!
Lo-Fi Version | Time is now: December 4th, 2024 - 8:42 PM |
