> 2000rpm when starting:-(
post Oct 27, 2011 - 9:00 AM
gadger
Joined Aug 30, '11
From hull
hi, my 1995 toyota celica GT is starting up at 200 revs..is this normal as it gets colder outside or does it suggest a problem somewhere? can i turn the revs down or is that not a good idea. any help would be much appriciated.
thanks
that should say 2000 reves on start up..
post Oct 27, 2011 - 9:03 AM
atikovi
Joined Sep 27, '11
From Suburban Washington DC
QUOTE (gadger @ Oct 27, 2011 - 10:00 AM) *
thanks
Maybe bad temp sensor. Computer thinks it -40F and richens the fuel mixture.
post Oct 27, 2011 - 9:07 AM
gadger
Joined Aug 30, '11
From hull
yeah that crossed my mind. anyway of testing it?? the revs do go down when the car is up to temp. its also had a new thermostat and change of coolant:-)
post Oct 27, 2011 - 12:20 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the ecu will idle high when its COLD out. near freezing, to help the engine warm up and keep a steady idle.
I think you're normal there.. the revs should go down to 1200 or less when the temp needle moves from pegged at cold.
post Oct 27, 2011 - 12:59 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
mines has been at 1700-1900a at start up since its been cold out here lately
it drops as the car warms up
so its nothing to worry about it just helps the car heat up
94 st hatch my daily driver
n
post Oct 27, 2011 - 1:06 PM
mkernz22
Joined May 10, '10
From MA
mine idle higher when it's warmer, but usually not around 2000rpm.
off topic; are you from hull, mass? cause I'm from right around the area
post Oct 27, 2011 - 1:18 PM
Needles
Joined Nov 18, '10
From montreal
all the celica i had did that, it goes to 1800 rpm at start at cold,
post Oct 27, 2011 - 7:13 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Ive owned 3 running celicas. thy all idled a little less than 1800 on a COLD start
post Oct 30, 2011 - 7:13 AM
gadger
Joined Aug 30, '11
From hull
QUOTE (mkernz22 @ Oct 27, 2011 - 1:06 PM) *
yes i am from hull:-)...well just outside hull..
its starting at 2000rpm when cold then only dropping down to about 1100-1200rpm when fully warmed up:-( it used to drop right down to 900rpm so i'm guessing there is a problem or am i barking up the wrong tree??
anyting i can try? can i manually knock the revs down when its started up??
QUOTE (gadger @ Oct 30, 2011 - 7:12 AM) *
oh and am i going to be using more fuel??
Lo-Fi Version Time is now: December 3rd, 2024 - 6:37 AM
