> Best injector cleaner??, What's best??
post Oct 27, 2011 - 9:26 PM
Bigblock
Joined Feb 14, '09
From Mid West
I'm wondering what is the best injector cleaner?
There are a few to choose from. So what do you folks use?
I'm stuck between Lucas & Chevron.
I have high idle, & a lil pinging between 30-45 mph. The gas here contains a minimum 10% ethanol.
Also, is it ok to use Heet Water Remover with injector cleaner?
Wondering if I have dirty injectors // water in my gas.
post Oct 27, 2011 - 11:13 PM
mak5603
Joined Oct 20, '08
I use the chevron one when I use it.
2014 Toyota Rav4 XLE
post Oct 28, 2011 - 12:48 AM
mandrek
Joined May 4, '05
From western MD/NOVA
post Oct 28, 2011 - 1:51 AM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
Injector cleaner doesn't do anything.. Sorry, you have to have more than that little bottle go through them to actually clean them. Some shops will run a high concentration cleaner through them that helps. That's what we did at school.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Oct 28, 2011 - 5:53 AM
Neon90424
Joined Jan 19, '11
hows about runnin straight AV Gas? l
post Oct 30, 2011 - 4:16 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Seafoam works best in my experience. We put it in one of my co-workers, girlfriends car, and it ran so smooth after the treatment, that she attempted to start it a second time after it had already been running. It's great for stabilizing and getting rid of moisture in the fuel too.
post Oct 30, 2011 - 5:17 AM
Bigblock
Joined Feb 14, '09
From Mid West
I never thought of Seafoam!
Tomorrow I'm going to make an appointment @ my friends shop
to hook up the injector cleaner machine.
When I get it running right I may use Seafoam.
Good tips here!!!
post Oct 30, 2011 - 8:37 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Witch hunter is the correct answer, but second best is to run it on a machine like a motorvac that we use at the shop. Run a concentrated solution through the fuel system after the pump and filter, this stuff also gets the cat good and hot to burn off deposits, honestly you can watch the cat light off faster AFTER the treatment, almost like a new cat again. Works great on sticky injectors, we had an old 2.8 GM V6 that sat for about 5 years with bad gas, 4 injectors stuck. about 45 minutes with the machine, had it purring on all 6 cylinders again.
Lo-Fi Version Time is now: December 2nd, 2024 - 5:45 AM
