Enthusiast ![]() Joined Sep 22, '10 From pomona, ca Currently Offline Reputation: 1 (100%) ![]() |
hey whats up guys, im in the process of turbo charging my 94 gt. everything is pretty much stock. i just rebuild the whole engine and ported and polished the head. i got all my parts ready, just had a few questions here they are:
i got some rx7 460cc injectors: are these too big, if im just gonna run about 10psi? i was also looking to buy a water/meth injection kit, will this benefit me if again, im running about 10 psi? i was also thinking of getting something to control the ignition timing ( MSD BTM), do i really need it " " " " " "? lastly, is it safe to run more than 10 psi on the stock block with the above components? any input/ recommendations is greatly appreciated =] my set-up: 460cc rx7 injectors 26x12x3 FMIC/ 2.75" piping generic t3t4 turbo, trim .50, a/r .63 SSBOV AEM wideband 02 stock fuel pump |
i got some rx7 460cc injectors: are these too big, if im just gonna run about 10psi? your gonna need somthing to tune with anyway, so no. [b] i was also looking to buy a water/meth injection kit, will this benefit me if again, im running about 10 psi? [b] yes. i was also thinking of getting something to control the ignition timing ( MSD BTM), do i really need it " " " " " "? no, although as you up the boost, with a unit like the emanage ultimate can control timing, fuel, and a bunch of other stuff as well lastly, is it safe to run more than 10 psi on the stock block with the above components? supershannon77 has a great build thread that use the same turbo. she made ~240whp @ ~11.5 psi, and ~ 285whp @almost 17psi. tuning was done with an SAFCII or Neo, i cant remember, its been that long..lol its prolly in the thread. you will kill the motor with the stock fuel pump. a walbro is cheap (100 or less), and pretty easy to install. get a foam sock for it, and it actually wont even be loud, like most people talk about. check out this thread that basicly takes you thru her whole build. http://www.6gc.net/forums/index.php?showtopic=52431&hl= good luck. any input/ recommendations is greatly appreciated =] my set-up: 460cc rx7 injectors 26x12x3 FMIC/ 2.75" piping generic t3t4 turbo, trim .50, a/r .63 SSBOV AEM wideband 02 stock fuel pump -------------------- Former Team 5SFTE pro member ;)
thanks for all that info!
made a bit more research, but i dont want to get the emanage right now. will i be ok to just use the SAFCII to control the injectors? i called a local tuner and he said if we use the SAFCII i would only be able to run about 8psi with my set-up and that my injectors would almost be maxed out, is that true? |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
not with the 460's those are big enough to run about 12 psi
You obviously didn't read the thread I linked.
I ran almost 17psi, controlled by an safc on shannons car, and still had to pull fuel, with the same turbo you want to run. -------------------- Former Team 5SFTE pro member ;)
well there is your answer, i was just being conservative on my estimate. 460s should be good for quite a bit of boost with out return style fuel systems
Lo-Fi Version | Time is now: February 21st, 2025 - 2:04 PM |
