> Head gasket issue?
post Oct 30, 2011 - 8:25 PM
block
Joined Jul 27, '06
From Soda
So I start my car and I see a crap load of white smoke coming out of the muffler. Now my car is revving high in 2k. Im guessing this is head gasket issue? If so, how hard is it to replace and should I replace the whole gasket ordeal or just the gasket itself. I'm not looking to put much more work into the car as it'll have a newer engine. If I could just replace one simple gasket and get away with it for 4 months, then it'll work. I guess it wasn't good to let it sit for so long and not starting kindasad.gif
post Oct 31, 2011 - 10:29 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its def a saturday job. does the smoke smell sweet?
also theres a deal u can get from an auto store that you can test your water for combustion gasses
post Oct 31, 2011 - 8:36 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
head gasket is no easy job for the inexperienced. there are alot of parts that have to come off first.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 31, 2011 - 9:07 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (Smaay @ Oct 31, 2011 - 8:36 PM) *
I agree. it took me ~ 6hours start to finish. im not the best mech but ive done it a few times, mostly on hondas though. that was my first 7a head
post Nov 1, 2011 - 12:30 AM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
Might help if you write a list of order and label everything you take off lol.. Helps with laptops atleast biggrin.gif
post Nov 1, 2011 - 2:47 AM
ricochet1490
Joined May 3, '11
From Ohio
white smoke is burning oil.... head gasket issues usually result in antifreeze in the pistons. Does antifreeze burn white? idk I've never looked it up... but oil definitely burns white. i don't know if I would jump straight to head gasket. monitor the situation and measure your oil to see if that's what's burning. also measure coolant levels and keep tabs. My first instinct reading this was rings.... but I could be wrong and it could be something much more simple.
This post has been edited by ricochet1490: Nov 1, 2011 - 2:48 AM
post Nov 1, 2011 - 9:07 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (ricochet1490 @ Nov 1, 2011 - 2:47 AM) *
Oil actually burns bluish. Coolant doesnt burn, but steams, which is white w/ a sweet smell to it.
If the valve seals are bad, you'd get oil leakage onto the valves and subsequently the combustion chamber, and a HUGE amount of LIGHT blue smoke at the first start up, if it sat very long.
post Nov 1, 2011 - 9:11 AM
ricochet1490
Joined May 3, '11
From Ohio
Well, white/light blue are close in color haha. But it makes sense. There are definitely some variables we need to know. is light blue what he meant by white. Does it smell like burnt oil, or sweet? Which fluid level is dropping? Both? What'd you find Block?
post Nov 1, 2011 - 11:37 AM
mkernz22
Joined May 10, '10
From MA
blue and white are completely different colors. The colors is very defined between the two if they come out of the exhaust. And the level doesn't really drop too to fast.
Is the smoke just on start up and has the car been sitting for a while?
post Nov 1, 2011 - 2:11 PM
block
Joined Jul 27, '06
From Soda
QUOTE (stephen_lee @ Oct 31, 2011 - 10:29 AM) *
stephen, there's a coolant smell everytime i turn the engine on. it's been blowing white smoke everytime i've turned the engine on. at first i thought it was piston rings or whatever. then i read more online and thought maybe it could be a headgasket. im probably not going to do a headgasket by myself. plus if it's more than 300 to do it + parts then im going to look at my buddy's beams swap.
QUOTE (mkernz22 @ Nov 1, 2011 - 11:37 AM) *
just start up. when im shifting and things like that, there's no smoke. wife says so haha.
plus coolant level has been good. i've had to refill it once but that was a while back when i took the car out of hibernation. oil level goes down slowly but i've always changed oil right at 3k miles and oil level seems to always be fine.
post Nov 1, 2011 - 2:23 PM
ricochet1490
Joined May 3, '11
From Ohio
well looking at a beams swap is never a bad thing tongue.gif keep us updated
post Nov 2, 2011 - 12:14 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Buy the headgasket fix at autozone for like $30. Make sure you get the stuff you can just dump into your radiator. If you need it to just get buy for a while i've had good success with it.
Not a permanent fix, but stopped the leak twice for me for a few months. Also if you pull the head, get it resurfaced, otherwise you could put it back on and itll be worse.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
Lo-Fi Version Time is now: December 2nd, 2024 - 5:41 PM
