> key n alarm, does not work..strange problem
post Dec 19, 2003 - 12:13 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
Hey guys, here is my problem..
My key alarm stopped working. One day when i pressed the lock button, the car did not lock n the alarm did not set. I figured it could be a problem with my key, so i pulled out my other key and it worked. Then i started the car, drove around. When i got out of the car and tried locking the car, it did not work. As i put the key in the key hole to lock the door, i felt some kind of leak in current which gave me a mild shok..
Can any of you help me with the problem..
Thanks,
Preetham.
post Dec 19, 2003 - 9:49 PM
Andason
Joined Jun 26, '03
From Wisconsin
did you check the battery?
the current is probably just a static electricity shock, i get them all the time.
i am awesome
post Dec 20, 2003 - 12:58 AM
DoodieHead
Joined Mar 31, '03
From Bowling Green, KY
sounds to me like a bad wire connection, did you do the install yourself or what?
post Dec 20, 2003 - 3:13 AM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
no, its the stock install..was working perfectly for all these years..
post Dec 20, 2003 - 9:39 AM
polishchacha
Joined Aug 18, '03
From North Augusta, S.C.
best idea would just to take it to a shop. I'm not sure, but it seems like something has shorted and bi-passed the fuse causing a constant current feed. Be carefull, if that is true, there is a good chance of something called "thermal run away" and you could burn up a lot more than your alarm wireing.
post Dec 30, 2003 - 12:28 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
Any idea on how can i get the stock alarm dis-armed...
My key switch does not seem to work...
This post has been edited by kingpreetham: Dec 30, 2003 - 12:30 PM
Lo-Fi Version Time is now: November 24th, 2024 - 11:26 AM
