7afe advance timing, anyone do it? |
Nov 5, 2011 - 7:02 PM |
Enthusiast Joined Jan 30, '11 From Albany, NY Currently Offline Reputation: 4 (100%) |
Ive heard about people changing to an advanced timing and that it helps a little bit. It seems there no cons to it so im thinking of doing it.
Has anyone done this? how hard was it to do? pros/cons? Also do you have to run higher fuel? This post has been edited by NYp8tBaller07: Nov 5, 2011 - 7:13 PM -------------------- Power in Balance 90 ST coupe- Sold 95 ST hatch- Dead :’( 02 Impreza RS- DD |
Nov 5, 2011 - 11:19 PM |
I know the NA (1st gen) Miata crowd bumps their timing from 10* to 14* BTDC. Not sure if the same can be done for a 7A, but it'd be interesting to see if it yields any usable results.
This post has been edited by SwissFerdi: Nov 5, 2011 - 11:19 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Nov 5, 2011 - 11:22 PM |
yes you can move it up quite a bit. just run 91 or better gas. its really impressive how good the 7A-FE responds to it
Nov 5, 2011 - 11:25 PM |
What would you recommend? I should technically be changing my timing belt around 100k anyway, and I'm at 96,6xx. As far as I know, drops gas mileage by a few points but pretty much creates a bit more power and "pep" across the rev range?
'93 MX-5 LE |
Nov 6, 2011 - 12:29 AM |
is there any how to for this?
Nov 6, 2011 - 12:46 AM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
year of the car?
in any case.... this is how I would do my 5s - might be similar for you. http://www.toyotacelicaonline.com/timing.htm -------------------- |
Nov 6, 2011 - 4:29 AM |
he said to rotate the dissy up. does he mean toward the firewall or toward the light, just want to be sure.
Nov 6, 2011 - 9:27 AM |
I'm pretty sure he means to turn the dizzy toward the firewall..... but a timing light used to check it will tell you for sure..... make a change, Check it. Reset your bridges up... check it. etc.... a quick google search on how to do it exactly with a 7a may prove to find something different on the jumper pins in the diag port.
Nov 6, 2011 - 12:54 PM |
I'm pretty sure he means to turn the dizzy toward the firewall..... but a timing light used to check it will tell you for sure..... make a change, Check it. Reset your bridges up... check it. etc.... a quick google search on how to do it exactly with a 7a may prove to find something different on the jumper pins in the diag port. Ill have to try harder to find a how to for the 7a, I figured doing this will be nice and I plan to do it soon so ill most likly make a how to for the site -------------------- Power in Balance 90 ST coupe- Sold 95 ST hatch- Dead :’( 02 Impreza RS- DD |
Nov 7, 2011 - 10:28 PM |
Enthusiast Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
i did mine up to 15* didnt notice much honestly, but it will make a very little gain in power.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Lo-Fi Version | Time is now: December 12th, 2024 - 8:43 AM |
