39 Pages V  « < 32 33 34 35 36 > »
> Chee La's celica progression thread thing, 7AFE ---> Greytop BEAMS
post Apr 16, 2019 - 9:21 PM
Box
Joined Feb 23, '12
From Warrior, AL
I think everyone might want to see it start more than Chee La at this point, we've been waiting in anticipation looking through the glass.
2001 Miata LS 5-speed
post Apr 17, 2019 - 2:27 AM
lets see.
air ------ check!
fuel --- kinda check... after few tries, have you removed the plugs, to see if they are wet, or smell like gas.
spark?
what makes the car spark? this is the quickest way to test your spark chee....,
crank sensor? is your timing off? check again, power to coils, power to injectors, sorry it sucks. but i bet its a ground you forgot to hook up, or its loose...
make sure the ecu pins are not bent, and make sure you did plug ecu
post Apr 17, 2019 - 10:33 AM
cheela
Joined Feb 2, '07
From Berlin, WI
I am the king of suspense and drawing things out longer than needed, like an episode of Dragonball Z.
thanks Norberto, I'll grab one of those and check those things over.
crank & cam sensors are plugged in
EA1 wires are bridged and plug is in tight
ECU plugs are all in and tight
grounds and sensors behind engine are checked and all present/tight
I'm gonna check power to the COPs and injectors, plugs etc and then check timing again. Those are the only two things I would think it could be at this point.
post Apr 17, 2019 - 3:06 PM
TimeslideZ
Joined Jun 9, '16
From Minnesota
That seems a little dangerous, no electrical tape or better soldering?
This post has been edited by TimeslideZ: Apr 17, 2019 - 3:07 PM
post Apr 17, 2019 - 3:26 PM
Box
Joined Feb 23, '12
From Warrior, AL
^ I was just about to do the same. There's a reason there's only two professional solder joints, either NASA or Western Union and that my friend is neither.
If it were me I'd Western Union splice the two wires of the harness together before doing a NASA splice between them and the wire of the plug. Then use some heat shrink. I'm OCD though, so your results may vary.
This post has been edited by Box: Apr 17, 2019 - 3:47 PM
post Apr 17, 2019 - 5:11 PM
cheela
Joined Feb 2, '07
From Berlin, WI
hahah. no that was just me opening it up to check because I'm losing my mind. (you can see the tape off to the right) It wasn't left exposed like that, I re-taped it tight afterwards.
post Apr 17, 2019 - 8:25 PM
Box
Joined Feb 23, '12
From Warrior, AL
That doesn't address the shoddy soldering. tongue.gif If it's just a glob of standard tin/lead solder between the wires you're losing a lot of electrical conductance versus straight copper, it's hard to tell from the picture if the wires are twisted together or if it's just a solder glob holding it all together. Used to you could get silver bearing solder from Radio Shack which comes in really thin spools, meant for doing electronics and is the only thing I use. A little better conductance with the added silver, and much easier to get a nice clean solder joint more importantly, though if you get the copper wires touching well before soldering conductance will be fine. YOU ARE BOTHERING MY OCD CHEE LA! *boards plane to Berlin, WI*
post Apr 17, 2019 - 8:34 PM
cheela
Joined Feb 2, '07
From Berlin, WI
lol. don't worry. the wires are twisted and soldered throughout. it's a good hold.
Hell, if you board a plane and make it here to help me get this damn celi started, I'll take you down to Chicago for the meet this weekend. hahaha
I've given up on OCD for this car, just needs to run first then I'll tidy everything up.
post Apr 17, 2019 - 8:46 PM
Box
Joined Feb 23, '12
From Warrior, AL
Fair enough. Ha if I had the money to blow and had the energy to fly up there I'd try and help, sometimes a fresh perspective on something helps. All else fails I'll swap in a 350 even though that's not what you asked for. laugh.gif
post Apr 17, 2019 - 10:55 PM
so explain to me how you did the clutch start. BEcause i cant remember if the ECU needs to get a Start signal to start?
post Apr 18, 2019 - 9:43 AM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (njccmd2002 @ Apr 17, 2019 - 10:55 PM) *
In the beams swap thread for the clutch start wiring, you move pin 18 of II2 to pin 17 of IJ1, I just moved it back.
basically, I used the auto neutral start path instead of the clutch start as they end up in the same places and then bridged the pins in the auto shifter wires pin 5 and 6.
that sound right? or did I just cut out the start signal by doing that? lol
post Apr 18, 2019 - 10:16 AM
TimeslideZ
Joined Jun 9, '16
From Minnesota
Box just come to MN and buy mine. Then drive over to Cheela's to help him with his. Of course after that show him what's up with the V6 when y'all go down to Chicago.
post Apr 18, 2019 - 11:11 AM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (TimeslideZ @ Apr 18, 2019 - 10:16 AM) *
lol. well right now my 7A is making more power than the BEAMS. laugh.gif and I didn't swap a BEAMS for big HP or anything. I just wanted a fun daily driver that I can rev to balls and back. I mean I have 30 min commute on empty country roads everyday. biggrin.gif biggrin.gif biggrin.gif
post Apr 18, 2019 - 3:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
Already tired of the V6? If it weren't for having to sell the Firebird and already having decided on a NB2 Miata to replace it I probably would, but I'd love to have it as a second car.
As far as the start signal that might be the issue, getting signal to crank but not to spark. At any rate it doesn't hurt to do it exactly as listed in the swap guide to make sure that's not it before banging your head against the wall any more than what you have.
post Apr 18, 2019 - 10:37 PM
Status?
post Apr 20, 2019 - 11:00 PM
TimeslideZ
Joined Jun 9, '16
From Minnesota
QUOTE (Box @ Apr 18, 2019 - 4:20 PM) *
Ha ha no, just joking about it. But I do hate not being to drive the car for nearly half the year.
post Apr 21, 2019 - 5:13 PM
Box
Joined Feb 23, '12
From Warrior, AL
I get that, though for different reasons.
Any Easter resurrection miracles?
post Apr 21, 2019 - 6:41 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
I'll have to go up and hot wire it. If we knew what he was missing...fuel pressure, spark, or injector pulse then this would be easier to figure out. My gut guess is the circuit opening relay isn't being activated.
post Apr 22, 2019 - 8:12 AM
cheela
Joined Feb 2, '07
From Berlin, WI
I'm ordering a spark tester and noid light so we'll see.
nope, no easter miracle, spent it with the 6gc family at the midwest meet.
Talking with them helped. I'll probalby PM them and bother them some more.
Was getting fuel all the way up the line to the rail but not sure if its making it through the injectors. I'll pull the spark plugs and check them too.
post Apr 22, 2019 - 2:28 PM
Bitter
Joined Mar 11, '06
C opening relay runs fuel pump I think, so that's probably ok. Uhhhhhh is the cam or crank sensor connected?
Lo-Fi Version Time is now: November 27th, 2024 - 12:50 AM
