5sfe valves |
5sfe valves |
Nov 8, 2011 - 3:22 AM |
Enthusiast Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
are there any 'performance' or lighter/stronger valves available for a 5sfe.
other than cams, whats available for the head? -------------------- For Sale:OEM tail lights - make offer
Nov 8, 2011 - 8:39 PM |
Anything? Springs?
Are the 3sge/3sgte compatible? -------------------- For Sale:OEM tail lights - make offer
Nov 8, 2011 - 8:52 PM |
why?
on a mostly stock motor, theres no reason for valves. but yu CAN port the head. polish combustion chambers, exhaust runners, etc. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Nov 9, 2011 - 10:21 AM |
i think i remember reading somewhere that Supra 2JZ valves have the same length stem, they are basically the same as an oversized 5S-FE valve.
Nov 10, 2011 - 1:15 PM |
i think i remember reading somewhere that Supra 2JZ valves have the same length stem, they are basically the same as an oversized 5S-FE valve. can anyone confirm this? if the stock fit should the aftermarket one fit too? @stephen. im not really doing this soon just thinking about it. "building my knowledge" also this guy i met an this meet with a camry said he had those so it got me thinking -------------------- For Sale:OEM tail lights - make offer
Nov 10, 2011 - 1:47 PM |
i just remember reading a thread on another forum that the Supra valves were almost identical to another engine, i cant remember if it was the 5S-FE or not. ill see if i can find it
Nov 10, 2011 - 2:09 PM |
ok i found the thread i think i was thinking of. its on MR2oc.com the author actually is recommending 2JZ-GTE valve springs for the webcam 294 cams.
Im about the pull the engine out of my Supra, the head is being done so i can measure the valves and let you know. i dont have any 5S-FE valves to compare to but if you have your head apart, measure the over all length, and diameter of the valve face and who knows? -------------------- 2001 Celica GT-S Turbo
Nov 10, 2011 - 6:15 PM |
i would really appriciate that... just one problem: how to u take them out? lol i have my old head sitting in the garage doing nothing so i can check it with that, any advice on how to do so, i got the shims out thats it lol
Nov 10, 2011 - 7:36 PM |
ok i found the thread i think i was thinking of. its on MR2oc.com the author actually is recommending 2JZ-GTE valve springs for the webcam 294 cams. Im about the pull the engine out of my Supra, the head is being done so i can measure the valves and let you know. i dont have any 5S-FE valves to compare to but if you have your head apart, measure the over all length, and diameter of the valve face and who knows? link? i've never seen aftermarket springs recommended for the webcams 294's...webcams dont recommend them for those cams. besides, before you get to O/S valves on a 5s head, there are lots of other things you can do to make lots of power before going for the small gains the larger valves will get you. i mean ya, if its already apart, and you have the extra cash, it may be somthing to think about..if your looking to make BIG power with a 5s head..but that wouldnt even be a thought in my mind without thinking about lots of other things like manifolds, turbos, engine control, LOTS of headwork..ect...lol if your looking to make n/a power (lol), google mrturrari, or research his posts on celicatech and mr2oc. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Nov 10, 2011 - 8:21 PM |
or..... a BEAMS head on a 5sfe bottom end built for 9k rpms.... EPIC
since we're thinking via text here... -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Nov 13, 2011 - 2:58 AM |
or..... a BEAMS head on a 5sfe bottom end built for 9k rpms.... EPIC since we're thinking via text here... That sounds fun lol... Btw I know vvt-I is "variable valve timing" hit what does that reall mean and how does it give more power? -------------------- For Sale:OEM tail lights - make offer
Nov 13, 2011 - 12:46 PM |
Nov 13, 2011 - 5:59 PM |
to get the valves out is really simple. set the head down on a flat surface. I use a 14MM deep socket with a 1/2 to 3/8 reducer and a 1/2 drive 3" extension. i tape them all together so its nice and solid. then smack the retainer with a mallet. the keepers will pop right out. assembly is another story. i made a special tool to compress the spring and i use a small pic to drop the keepers in.
http://mr2oc.com/showthread.php?t=308405 the second post -------------------- 2001 Celica GT-S Turbo
Nov 21, 2011 - 4:18 AM |
Apperently I still dont have access to the link...I registered even since thank link and still don't have permission from moderators...
Anyways...if not too much to ask, Can u copy paste the info here or print screen the pages? Thanks -------------------- For Sale:OEM tail lights - make offer
Lo-Fi Version | Time is now: November 25th, 2024 - 6:43 AM |
