2 Pages V  < 1 2
> drifting st205, how'd he just get rwd?
post Nov 13, 2011 - 11:11 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
just checkin lol i second guessed myself there for a second
post Nov 14, 2011 - 2:43 AM
brenton1919
Joined Feb 28, '11
[quote name='easternpiro1' date='Nov 8, 2011 - 12:22 PM' post='940022']
i know this video is old, and its a noob question, but how'd he get the car to be only rwd? i was told you cant adjust the front/rear bias, and its very difficult to make it only rwd... never been clear on how people did it...
the car is awd. sooo all u have to do is block off the front two axles hole with a custom made plate. u dont need the front axles the car will still go if u take them out. so if u take them out the car becomes a rwd car its not hard if u already have a gt4
post Nov 14, 2011 - 1:13 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (brenton1919 @ Nov 14, 2011 - 1:43 AM) *
QUOTE (easternpiro1 @ Nov 8, 2011 - 12:22 PM) *
No sir. Unless the center diff is a clutch type or viscous limited slip(ST205 is not IIRC, its just an open dif and will send ALL power to the axle with the least traction, in this situation the front axle) and this setup willl not last long at all in a racing application. A "locking" diff like was avaliable in the previous GT4s would last longer. That's with a simple block off plate.
Another option which would only work with an open center diff, would be to make the block off plate with an axle stud welded onto it, mating with the front dif and the plate bolted to the trans, essentially making it appear to the diff as wheels that are locked up, and the way an open diff works, the center diff will send all power to the rear wheels. But again, this wont last, but much longer than the first option
Best bet would be "weld" the center diff, then block off the front axles. but this is a pretty permanent thing, and pretty...shoddy way of doing it.
Edit: the "quote" was screwey. and added another possibility.
This post has been edited by stephen_lee: Nov 14, 2011 - 1:30 PM
post Nov 14, 2011 - 1:20 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
I think this should be in the main forum as it applies to the Celica and has pretty good info in it..
post Nov 15, 2011 - 12:46 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (stephen_lee @ Nov 14, 2011 - 3:13 PM) *
I don't know if all St205's received it, but mine has an LSD in the rear and a Torsen in the middle. What would happen if you'd block the front axles? Would it be a better way to get a Gt4 rwd? I guess it'd end up burning too eventually?
post Nov 15, 2011 - 12:58 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
A torsen/helical diff is an odd one. It requires SOME resistance on the wheels with little traction to transfer the torque to the wheels with the most. In this case I don't know of a way to fool that diff, other than welding.
If you simply block the front axles, the dif will send all the power to the free spinning side (front).
If you lock the front axles, the torsen will think the rear is slipping so it'll transfer ALL torque to the front axle.
UNLESS my my understanding of the different types of differentials are off. If so, someone please correct me.
post Nov 15, 2011 - 1:19 PM
czwalga
Joined Sep 27, '10
From pittsburgh
The ST205 doesnt have an open center diff. The front is open.
My understanding is that the center diff provides a non adjustable 50/50 power split between the front and rear. If neither front wheels are not moving and the rear is, for a significant period of time you're going to burn up the differential.
It's why handbrake turns arent recommended because you lock up the rear wheels but the fronts are still turning. That said i've done this many times, but try not to lock them up for vary long, just enough to get the car rotating properly, but I also have 2 other transmissions sitting in my garage waiting incase I destroy one.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Nov 15, 2011 - 1:26 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
So its some sort of limited slip. I wonder which kind? Clutch type?
post Nov 15, 2011 - 1:41 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (stephen_lee @ Nov 15, 2011 - 1:26 PM) *
The front is open, center is a viscous, and the rear is torsen. I'd prefer a clutch in the front and rear, however usually the only stock cars that come with those are rwd muscle cars. The plates do wear out though and when they do it almost acts as an open. But you can get a good amount of use out of them.
-10 F150
post Nov 15, 2011 - 1:51 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (czwalga @ Nov 15, 2011 - 12:41 PM) *
Ah, a viscous will not last long at all. It would heat up pretty quickly and kill the fluid.
I'm running a viscous in my V6.
post Dec 12, 2011 - 3:17 AM
CelicaST18
Joined Sep 1, '04
From Ohio
you could weld the center diff to make it fixed front to rear and take out the front axles to make it RWD.. like i did in my WRX wink.gif had no problems with the center diff and its reversible.. just need another center diff
This post has been edited by CelicaST18: Dec 12, 2011 - 3:20 AM
2 Pages V  < 1 2
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 20th, 2025 - 12:49 PM
