Enthusiast ![]() Joined Sep 6, '10 From usa, tucson, az Currently Offline Reputation: 0 (0%) ![]() |
i got just the ct20b what do i need to put this on my 2nd gen
New oem gaskets, time, and patience.
Also a great time to replace your hose from hell. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) ![]() |
New oem gaskets, time, and patience. Also a great time to replace your hose from hell. well, besides the exhaust manifold being totally different on each end, what do you recommend he do for that? Kevin There is nothing different about the exhaust manifold as it bolts to the turbo. You just bolt your ct20b directly to the 4 studs/bolts. The only difference is that the downpipe side of the turbo has an extra stud than the ct26 downpipe. All you need to do to fix it is remove the extra stud from the turbo. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Im so confused... I thought the 2nd gen had a large round entry point from the exhaust manifold. or is that the gen 1?
Im so confused... I thought the 2nd gen had a large round entry point from the exhaust manifold. or is that the gen 1? You are thinking of gen1. A lot of people have ct20b's on their 2nd gen engines, myself included. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Im so confused... I thought the 2nd gen had a large round entry point from the exhaust manifold. or is that the gen 1? You are thinking of gen1. A lot of people have ct20b's on their 2nd gen engines, myself included. so does it also have the Dual entry? I cant actually find a picture of the exhaust inlet. |
Lo-Fi Version | Time is now: February 13th, 2025 - 12:17 PM |
