AT200 to GT4 rear disk |
Nov 13, 2011 - 1:25 PM |
Enthusiast Joined May 29, '09 From Chile Currently Offline Reputation: 0 (0%) |
Drums to GT4 rear disk brake, is possible?
Regards |
Nov 13, 2011 - 1:45 PM |
Enthusiast Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) |
Drums to GT4 rear disk brake, is possible? Regards I know you can do the GT disk brakes but not for sure about the gt-4 -Matt This post has been edited by matts94celica: Nov 13, 2011 - 1:46 PM -------------------- |
Nov 13, 2011 - 7:14 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
Are you a troll!?
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Nov 13, 2011 - 10:36 PM |
I read about the front disk conversion to gt4 and said it was difficult because of the superstrut. They had to make custom brackets to support it. You would need to see if the rear has extra brackets like the front because of the superstrut and if it does see if you can make some brackets to support it.
Nov 15, 2011 - 6:44 PM |
Enthusiast Joined Apr 18, '11 From Southern Alabama Currently Offline Reputation: 1 (100%) |
I read about the front disk conversion to gt4 and said it was difficult because of the superstrut. They had to make custom brackets to support it. You would need to see if the rear has extra brackets like the front because of the superstrut and if it does see if you can make some brackets to support it. completely different knuckle i tried wont work only way around is to do the GT conversion - using GT knuckle and Hub and using the GT4 caliper and rotors as the rotors and calipers mount to the GT knuckle and hub this is what am in the process of doing. its been said and confirmed in the stickies that GT and GT4 calipers have the same mounting points for more details on how it works read the stickies on drum to disk conversion and then the rear gt4 conversion for the GT for the fronts just switch to superstrut they are awesome idc what anyone says lol (unless u get bad shocks then its a nightmare) |
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:56 PM |
