> Alternator
post Nov 15, 2011 - 5:08 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
I recently replaced my alternator last month and I have noticed a decrese in fuel economy.
Do Alternators affect fuel economy in any way? This is assuming that no other factors are changed like tire pressure or tune up.
Thanks
God made man....
Everything else...
Made in China
post Nov 15, 2011 - 8:41 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Yes
post Nov 15, 2011 - 8:54 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
The alternator runs off of your engines power. Just like EVERYTHING else in, on, or attached to your car.
Add weight, lights, system, roof rack, etc will affect MPG.
A new alternator has tighter bearings = more drag on the engine. Or maybe it has a lower efficiency which means it takes more torque to produce the same amount of amps.
I wouldn't expect a noticeable drop in MPG though. maybe 1 at the most. was the belt over tightened? That will cause unneeded drag. Are you sure nothing else changed?
post Nov 16, 2011 - 4:23 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
Just the tire pressre was low. I will see on my next trip to SoCal if that was just the tire pressure.
How will I know if the belt is too tight? When I replaced it, I went to autozone to get it checked and the guy said that the tension is fine.
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: November 28th, 2024 - 8:29 PM
