> Knocking brake, Brake got hot
post Nov 24, 2011 - 4:01 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
I installed steel rims yesterday and everything was fine before I did. When I took it out the rear right wheel started knocking. I first though maybe I did something wrong while installing the rim. But I took it off and put it back on, everything seemed okay. Though the lugs were hot and the brakes were very hot, could barely touch the disk at first.
Any ideas?
post Nov 24, 2011 - 5:16 PM
mkernz22
Joined May 10, '10
From MA
what size rims are they?
are they rubbing on the caliper at all?
post Nov 24, 2011 - 11:55 PM
If you're still speaking of the GT-4, then, to my knowledge, there is not a steel wheel that fits in existence, therefore you must be rubbing on the caliper.
Look at the offending corner and study the potential contact surfaces on the caliper and inside of the wheel barrel.
This post has been edited by SwissFerdi: Nov 24, 2011 - 11:56 PM
post Nov 27, 2011 - 4:13 PM
mrmatt
Joined Sep 29, '11
From Newtown CT
i had this exact same thing happen to me when i first got my celica. i hadn't changed anything yet, so i dont think it would be the rims. check the parking brake shoes inside the rotor. i found that to be the cause in mine.
Lo-Fi Version Time is now: November 25th, 2024 - 11:18 PM
