R/C Top Mount, Power? |
Nov 30, 2011 - 10:17 AM |
Enthusiast Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Hey guys, I tried searching the threads but I came up with no answer. If there's a topic about this already, I apologize in advance. I was looking to see what is the most amount of power that a 3SGTE (3rd gen) has made with a radiator cooled top mount? I am planning on getting one (trying not to display that my car is turbo'd by changing my front mount) and I was just curious. By the way, that's not the only reason I want to change to top mount, I have other reasons which I will not bore you all with. I just wanted to know how much power the radiator cooled top mount can keep up with. Also, any info on this top mount, such as pro's & con's, would be greatly appreciated.
EDIT: Also, this may be a dumb question but would the top mount fit with the oem hood, or would I have to upgrade to the GT4? -Thank you for your time, Ryan This post has been edited by str8thugginit4ya: Nov 30, 2011 - 10:32 AM |
Nov 30, 2011 - 1:11 PM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
long time ago i was in contact with a guy from denmark, he used the TTE group a setup, iirc he drives with ~700HP (DIN) he compared the setup with a HKS type R & S air to air setup and found that nothing was able to cool better as the TTE one, with a faster spool up of ~400rpm (no pipeways -> less pressure drop with the tmic system) the TTE tmic has one more row (8 instead of 7 rows, overall ~ 1 cm higher), internal air baffels, and a higher water backpressure -> possible a different radiator design i think you need a GT4 hood..... hope it helps greetz This post has been edited by Sunny: Nov 30, 2011 - 1:23 PM -------------------- |
Nov 30, 2011 - 3:24 PM |
^^^Thanks a lot. I'm assuming "TTE" stands for Toyota Team Europe? Not too sure. Ok, I'll have to find out 100% if I need the GT4 front for the top mount to fit.
-Thanks again, Ryan |
Nov 30, 2011 - 3:43 PM |
Hi,
that is correct, it is the team that build the toyota rally cars (years ago) greetz This post has been edited by Sunny: Nov 30, 2011 - 3:43 PM -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:05 AM |
