Intermittent Starting Issue, 1996 ST 25th Gen |
Dec 3, 2011 - 10:16 PM |
Enthusiast Joined Jul 16, '05 From Vancouver, BC Area Currently Offline Reputation: 2 (100%) |
Hey there....lately, every so often, I turn the key and the lights go on, but the engine doesn't start, or even budge (the starter isn't moving). After a random number of repetitions turning the key, the car starts (it's always less than 10 tries).
Everything else is perfectly fine. What gives? |
Dec 3, 2011 - 10:25 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Sounds like a bad ground to me. Or, your starter is on it's way out. Check your grounds on the starter, block, frame, and neg battery post. Also, check all of your power leads as well. Sometimes that nut on the starter works its way off.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Dec 4, 2011 - 9:33 PM |
I think it has to do with the starter. Do I need to replace the entire starter or just some component?
Dec 5, 2011 - 2:01 AM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
I think it has to do with the starter. Do I need to replace the entire starter or just some component? I second the starter what happens is the windings get egg shaped(toasted) 0 and it starts only when in the right place. The battery could be the culprit but a bad starter will request extra power to start even if the battery is good it can seem bad, hope that makes some sense. |
Dec 5, 2011 - 6:21 AM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
do the starter start fine evertime the engine is warmed up? it sound to me that the starter contact are worn, if your car uses a denso starter, is it just a simple replacing work fur just a few dollars greetz -------------------- |
Dec 5, 2011 - 10:35 PM |
Enthusiast Joined Mar 26, '10 From Bronx, Ny, 10466 Currently Offline Reputation: 3 (100%) |
Theese cars have fusible links on the positive battery cable. The next time it doesnt start on the first turn of the key, get out and roughly shake the positive cable abd then try again. Most likely u have a bad fusible link.
Dec 6, 2011 - 2:04 PM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
You need these: http://www.nationsautoelectric.com/densoparts.html
Toyota actually sells them also, starter/solenoid contact repair kit. local dealer had them in stock, really easy to replace. Just done the wife's Celica last month. EDIT: The Toyota kit costs more, but comes with everything you could need instead of just the 2 contacts, seals o-rings, gasket and new copper terminal studs. Watch the video EDIT EDIT: shouldn't need the plunger, just clean up the copper on the plunger This post has been edited by 97GTinKC: Dec 6, 2011 - 2:10 PM |
Dec 6, 2011 - 2:12 PM |
Ironically, My Harley also had a Denso starter and the exact same problems, on the good side, it's about all that ever goes wrong with these starters.
EDIT: FWIW, the ones in the video are not all that worn, my wife's were bad enough they were about a 3rd as thick as the new ones. The Harley literally had no contact left, just about an eighth of an inch at 1 end of the battery side still making contact, and it was paper thin, the rest was gone. the plunger was bottoming out in both causing a poor to no connection across the solenoid, then the contacts tended to arc and burn up even faster. I did not use a new plunger in either, but maybe should have, at least in the bike. Toyota also has the plunger kit separate This post has been edited by 97GTinKC: Dec 6, 2011 - 3:39 PM |
Dec 6, 2011 - 5:13 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
I have a starter for sale from my st if your interested, was only on the car for about 6 months before the swap, will let it go stupid cheap if your interested
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Lo-Fi Version | Time is now: November 30th, 2024 - 9:27 PM |
