> Major ABS problem, Need to identify the problem
post Dec 6, 2011 - 5:30 AM
Panic
Joined May 8, '11
From England
I took my celi in for its MOT last weekend and it failed on the fact the ABS doesn't work. As it turns out the not very nice man (who I'd quite like to punch right now) has disconnected the light from the dash so it doesn't show up.
I need to know what the most likely problems are. It locks all four wheels under heavy braking and all the sensors and relays seem to be working and getting power. My mate is doing the repairs at his garage for me but hasn't worked on a 6th gen before
I really need help with this as I can't drive until I get it sorted
post Jan 26, 2012 - 9:24 PM
Neon90424
Joined Jan 19, '11
I need help figuring out how to make the ABS work again on my gt4 as well, since the disc brakes were changed and new pads put in the abs light has come on and I don't like going sideways when I hit the brakes.
any tips guys what to look for and check out
post Jan 26, 2012 - 10:13 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
get the code/codes and go from there.
post Jan 26, 2012 - 10:19 PM
Neon90424
Joined Jan 19, '11
oh ok thanks man,
post Jan 28, 2012 - 1:21 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
diagnosing abs is a BIIIAAATCH!!!! ive been fighting with mine for a while now, finnaly got it down to all 4 abs sensors are done, the fronts were broke and some idiot just bolted the broken parts back up there, the backs just had no resistance between terminal and ground. first thing is pull codes, second thing is check your relays(better have the BGB open for this), third run secondary code search to diagnose speed sensor issues(if thats what it is), fourth check sensors themselves its the easiest part besides pulling codes, for the rear the sensor plug is inside the car behind rear seats on strut tower, test both sides,disconnect abs sensor from the harness. measure resistance between sensor terminals. resistance should be 800-2100 ohms, then measure resistance between each terminal to body ground, if it does not read more then one megohm it is a bad sensor. for the front the sensor connector is located under the splash shields, test resistance between the terminals it should read 600-1800 ohms. then test resistance from terminal to chassis ground. it should read one megohm or more. if it fails one or the other sensor is bad. this info is found on page 11 of the ABS portion of the BGB(if you have it downloaded and its individual pdf's.), i would not buy the sensors new if thats your problem they run at the cheapest 161$, luckily camry sensors will fit usdm hubs.(im not sure about the gt-four's or superstrut conversions) good luck diagnosing this pain in the rear ABS system,
post Jan 29, 2012 - 9:08 AM
4v6
Joined Jan 15, '12
From UK
With the vehicle raised off its wheels, disconnect each of the sensors in turn and attach a digital voltmeter to the sensor terminals.
Set the meter to read Volts AC (alternating current) then spin the wheel by hand.
You should generate a voltage if the sensor and reluctor ring on the driveshaft is good, can go as high as a couple of hundred volts at the kinds of speeds the car can get to, but in this instance, all we want to see is a nice AC signal telling us that the sensor is seeing the teeth of the abs reluctor ring as it passes thru the magnetic field of the sensor.
Hope thats some help!
This post has been edited by 4v6: Jan 29, 2012 - 9:09 AM
post Jan 29, 2012 - 9:37 AM
Neon90424
Joined Jan 19, '11
wow great stuff guys thanks!
Lo-Fi Version Time is now: December 2nd, 2024 - 5:05 PM
